Old 03-10-2013   #1
Cal55
Default Rear hatch drain hose question.
I was thinking about installing these because of all the water that puddles there after washing the car. I'm not to keen on drilling holes though. I was just wondering from anyone that's installed them how satisfied they are with them and if it was worth installing them.
Thanks,
Joe
Cal55 is offline   Reply With Quote
Old 03-10-2013   #2
vilant
Default Re: Rear hatch drain hose question.
If you pop the hatch, you'll see a small channel between the weatherstripping and the gas cap door (at least it's like that on my 1990) for water drainage. If your talking about the corners towards the front, I just stick the corner of my shami in there, when drying, to soak up the water. You could drill a hole if you want. But I'd be cautious about drilling holes anywhere.
Joe
1990 Bright Red ZR-1 #2599
Old 03-10-2013   #3
Had then on my 89 L98 and have then on my Z.. Love them
Old 03-10-2013   #4
Cal55
Thanks for the reply to both you and Jeff. Yes, I am talking about the corners toward the front. They sell a drain kit but I'm a little leary about drilling holes in the body. I use a chamois also but mine doesn't dry it totally. The link below shows the kit I'm referring to.
Take Care,
Joe
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Old 03-10-2013   #5
Mystic ZR-1
Mystic ZR-1's Avatar
Don't drill any holes. Just swipe your wife's turkey baster
when she's not looking...
Works great!
Old 03-10-2013   #6
Cal55
I thought about that too or using a plastic 60cc syringe.
Thanks,
Joe
Old 03-10-2013   #7
Available at any pharmacy.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 03-10-2013   #8
efnfast
Actually, I use the turkey baster to suck the water out of the hood lock holes. Thanks Doug, now it has another use.
Old 03-10-2013   #9
Mystic ZR-1
Steve
Don't put it back in the kitchen drawer.
Your T-giving turkey may taste funny...
D
Old 03-10-2013   #10
efnfast
Huh, that explains that. Thanks again.
