03-08-2013 | #11 | |
Re: My fuel injector change improved:)
Good job and great "How To" write up Cliff
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-09-2013 at 10:52 AM. |
03-09-2013 | #12 |
Why thank you, Cliff. Solutions helped me a lot w/ that. After I finish reading my automotive training manual, maybe I'll have the courage to try a 500hp rebuild. I'm a little ways from that yet though. But the info is there.
Joe 1990 Bright Red ZR-1 #2599 |
03-09-2013 | #13 |
Joe,
Not sure I am quite as meticulous as u are in documentation. Guess I have done it enough times, the picture is in my head at this point. Good job. Pete and Al wear blindfolds.
03-09-2013 | #14 |
With the plenum removed, and especially the coil packs, th grounds are not that hard to access. I should have done the rag trick to the drainhole. I only drilled mine out to 3/8" and flushed it with acetone.
