Old 02-21-2013   #1
dg463
Default Battery trouble
My ZR1 has been sitting for a while,and when i went to start it,the battery was weak, so i thougth lets give it a charge , but when i applied the terminals, it showed about 80 % charged on the charger screen readout, but then the charger went crazy, with the needle swinging wildly to the opposite side at the same time the charger started making a weird noise,needles to say i disconnected the he charger, and know battery id dead,any ideas, the battery is an Interstate.
dg463 is offline   Reply With Quote
Old 02-21-2013   #2
scottfab
scottfab's Avatar
Default Re: Battery trouble
Whatever you try, I'd disconnect it from the car before trying it.
Scott
Old 02-21-2013   #3
dg463
Question Re: Battery trouble
Im going to take it off,no sure how and take it to the local interstate battery store, and see what they say ???
Old 02-21-2013   #4
vilant
I disconnected mine when I charged it, and it said to put at least 24" of cable between the negatives of the charger and battery. I have a basic charger though. Make sure the terminal bolts aren't stripped, you can get a bad connection that way and get some weird happenings. I know, cause it happened to me.
Joe
1990 Bright Red ZR-1 #2599
Old 02-21-2013   #5
dg463
I believe you are right as I took it off and applied the charger to it, and its taking a charge without funny noises from the charger,anyways I will take it in the morning and have it checked out, and if it has no dead cells, I will charge it overnight at home,thanks for your help !
Old 02-21-2013   #6
gbrtng
gbrtng's Avatar
It's possible your charger is flakey. Best to pull the battery and have it checked by your local parts store first.
Old 02-21-2013   #7
The info on Marc's website regarding battery care might be useful.
http://www.zr1specialist.com/HAT%20W...ery%20Care.pdf
--Bob
