![]() Join Date: Sep 2006
I don't have the manual and am unsure how to test for TPS voltage....not sure what pins to check with multimeter etc.
I have been experiencing a high idle 1000 at startup and 1500 at a stoplight. Changed out the IAC which was dirty. Checked for loose vaccum hoses...didn't find any, checked ECM connections all ok,..so now I am at the TPS. Thanks! hpb |
![]() Join Date: Dec 2004
The easiest way to do TPS voltage is a scan tool. Next is get ya some sewing needles and back probe the wire at the connector, be careful that you don't stab the insulation but get the needles into the brass terminal ends of the wire inside the connector.
The first time I checked my TPS voltage I had some phone wire laying around and made small probes from that, about 2" long and used a small needle nosed pliars to insert it into the back of the connector. At idle TPS = .54 volts. Did you go over to the netreg site and look up the PROM recalls & TSB's? Ther were a coupla of updates to address idle problems. The TSB's describe the symptoms and cures (new PROMs) by model year. ![]() Tom Oh, forgot I think Corvette Central or MidAmericaMotorWorks has hraness test kits that you can buy to use to back probe all the main connectors, TPS, IAC, IAT, Oil & H2O....ya know ya yank the connector and put their connector in and it is a "Y" deal with a place for ya to put the VOM probes and still have the sensor in the loop.
#3 | |
![]() hpb |
Hey hpb you're welcome!
I have a 90 so I have the 90 FSM but if ya need anything looked up shout at me & I'll go lookie see what's in my FSM. We're all brothers o' the beast so we help each other....man you should read some of my old threads...talk about a noooob! I was so intimidated by the whole package that I was afraid to look at it too hard ![]() If I remember right the TPS is a three wire affair, a 5v reference line(gray), ground line(black), and a signal line(dark blue) .46v to .6v, .54v is considered to be good. I'm still only a third year apprentice but ya gotta love how these cars make ya feel when they are right! ![]() ![]() Tom
I would think the high idle is more likely caused by a leak somewhere than by an improper TPS. But I could be wrong. I'm not sure how a high-reading TPS could actually cause the motor to run much faster since it needs air to do that.
Did you clean the throttle body when you replaced the IAC? |
#6 | |
I replaced the TPS....the original was set to .34 but it was probably good. Checked for vaccum leaks and could not find any. Got a QDM1 fault YES on the scanner. Noticed a hard to reach throttle cable stop but I don't want to mess with it. Wierd thing is the speedometer is always reading 60mph to 220mph. New TPS set to .54 did not fix the problem. I drove for 1 hr and idle suddenly came back to about 650 where it is supposed to be but I expect it to be high again when I start engine today. Real mystery. Hope I don't have to change the ecm. hpb |
#7 | |
My problem is a faulty PCV valve connector tubing. The paired PCVs connect into a piece of rubber tubing about 10" long that runs along the rear of the block. You'll see if when you find the PCV valves. After taking the tubing off, I could see that there are a number of very very small tears that are likely the source of my vacuum leak. A replacement house made from silicone is available from White Racing Products. I also removed the plenum to check for vac leaks, removed the coil packs and starter to clean out the crap down in the valley, then cleaned everything well. In hind side, I'm glad I did all of this as there were clearly some mouse/rat droppings by the starter and my little friends had clearly been eating at insulation to the starter! Replace the PCV valve hose and you'll be set. Watch out though. That little hose is over $150! I also rewelded the braces that connect to the aluminum tubing which connects to either end of this PCV tubing. One was snapped off and I didn't want to even think about how much it would cost to buy it new. |
#8 | |
hpb Last edited by hpbadger; 04-03-2007 at 08:14 PM. |
#9 | |
Do not touch the throttle stop screw. These came preset and Mercury Marine never adjusted them either. If you do adjust it you are masking the real issue. |
#10 | |
