Old 02-09-2013   #11
Default Re: Crankshaft Position Sensor Air Gap Clearence
Let me correct that 702 had a shim, that went into 966...I will check the 966 motor tomorrow
Old 03-11-2014   #12
Scrrem
Scrrem's Avatar
The engine I purchased and am building not did not have the sensor or shim present. I guess the only way I will know if I need a shim or not is to install the sensor and measure the clearance.
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 03-11-2014   #13
WVZR-1
Only the early cars with the early DIS require the shim, when replacing with the later DIS and the appropriate CPS I don't believe there is a shim requirement. I believe the air gap needs measured and confirmed but I don't believe there was any requirement for specific air gaps. It's been a long while but that's best I recall!
I just looked and there is 3.0mm, 3.25mm and 3.65mm applications and it does say '90 - '95!
