View Poll Results: What would you go for? | |||
Finished unit for $50ea (2 needed) | 10 | 58.82% | |
Kit for $25ea (2 needed) | 6 | 35.29% | |
Other (reply in comment with specifics) | 1 | 5.88% | |
Multiple Choice Poll. Voters: 17. You may not vote on this poll |
Thread Tools | Display Modes |
02-06-2013 | #31 | |
Re: Under Hood Lighting
Yes Phil since this is a direct bulb replacement. Cant wait to get my hands on a pair of these.
02-06-2013 | #32 |
Sign me up for a pair. I would need to have these built as I suspect most of the membership will.
02-06-2013 | #33 | |
This poll is for 7 days ONLY. Anything after that may or may not get serviced since this is not a business for me. I design things. That's the fun part Cranking things out is drudgery.
02-06-2013 | #34 | |
First in your poll Scott do you take Paypal? GC
02-06-2013 | #35 | |
I noticed my underhood lights don't turn on, are they supposed to come on when you lift up the hood? I wonder now if I have a switch , or if they are just burnt out. If they are burnt out, is that common since our cars are pretty old now? If there is a switch ... where is the common place to install it (where should I look?) Thanks ---
[SIGPIC][/SIGPIC] 01' Dodge Viper GTS 11' Ford Raptor 90' ZR-1 Corvette LPE #699 |
02-06-2013 | #36 |
Yes, paypal will be fine but not quite yet. Based on the numbers I have to see if I need to hire someone to make these for me
Then I'll post pay options. The assembly is not really trivial
02-06-2013 | #37 | |
Next check the inline fuse. Maybe it was removed. Then look for any switch that may have been installed. Most are put in the cove under the drivers headlight. Lastly you can inspect to see if the bulbs were just taken out or are popped. The mercury switched would be last. You can tap on them to see if they've become intermittent.
02-06-2013 | #38 | |||
It could be anywhere however mine is on the drivers side next to front of the tire in the engine compartment.
02-06-2013 | #39 |
Thanks Scott and GC ... if I can get these working I may be interested in the GP too ---
02-06-2013 | #40 |
I want a set
