![]() Join Date: Aug 2006
Are there two separate sensors for oil temp (analog and digital)?
Anyone know where analog sensor is located? |
#2 | |
![]() Join Date: Oct 2004
Where do you see Oil Temp digitally? Temp horizontal front of Oil filter adapter, light is vertical pointed down and gauge is vertical on top! I believe! Last edited by WVZR-1; 01-25-2013 at 02:39 PM. |
Yun,
Far as I know there is just one oil temp sensor located in the oil filter/thermostat regulator assembly below the lower oil cooler line pressure fitting. If you need one Jerry has them listed http://jerrysgaskets.com/store2/root...roducts_id=184
#4 | |
94s you can scroll trough coolat temp, voltage and oil temp numerically on trip computer screen (inst. mpg, ave. mpg and range). I don't think my 91 had digital gauge. Reason I am asking is that oil temp digital reading is accurate but the analog gauge reads hopelessly low. So, I was wondering if there are separate senders. Based on experience when readings were off it typically was due to faulty sending unit and rarely the gauge. |
#5 | |
The analog oil pressure gauge its the sending unit on top of the oil filter housing. I know this as several years ago mine dropped to zero!!!! Also using the Red Service Manual you can get all the same detail by reading the Digital C60 display on the AC next to the correct codes for the M& 90- MY91 models. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-25-2013 at 04:43 PM. |
#6 | |
Is this it? http://compare.ebay.com/like/3707171...Types&var=sbar |
#7 | |
*There's a descriptive note with the temp sensor that it's also used for the oil life indicator and it's a 3 pin switch so I believe it's all on the single sender. It's still available I wouldn't rush into a panic buy. It's a shame it's so difficult to get to! It would be interesting to have others confirm the reading comparisons digitally compared to the analog display! Maybe there's no cause for concern. What are your values? Is the digital a *C or a *F? Last edited by WVZR-1; 01-25-2013 at 04:36 PM. |
#8 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-25-2013 at 04:42 PM. |
#9 | |
#10 |
![]() Correct
