Old 01-22-2013   #1
Wink What Is It?
I lost my mind...where do these T-40 and two clips go under the hood or on the LT5?
No...This is not the first time I had brain freeze
Thanks,
Cliff
Old 01-22-2013   #2
scottfab
scottfab's Avatar
Default Re: What Is It?
The T40s are for the rear hold downs for the roof panel.
The others are from a 60 series John Deer combine
http://talk.newagtalk.com/forums/thr...23&mid=1388269
Scott
Old 01-23-2013   #3
MikeGolf
Doesn't the silver clip hold the tranmission cable to the upper left side of the transmission? The small hole holds the plastic holding tab for the cable.
'93 #166 Black Rose
“Out of every one hundred men, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back.” Heraclitus
MikeGolf is offline   Reply With Quote
Old 01-23-2013   #4
DaveK
The ones on the left are self-sealing stembolts, the ones on the right are phase coil induction mounts...
Dave
1991 #1516 Black/Black
davidmkelly.com
"Speed is often confused with insight." - Johan Cruijff
Old 01-23-2013   #5
MikeGolf
http://zr1.net/forum/album.php?album...pictureid=1936
http://www.zfdoc.com/S640Parts.htm
'93 #166 Black Rose
Old 01-23-2013   #6
Pete
Pete's Avatar
The screws look like from the trg top.
The silver bracket is to hold down the vent tube for the transmission and the harness for reverse switch,1-4 skip plug,and speedo.
The other looks like it holds a harness wire loom that goes over and around the rear end tunnel just over the C-beam and rear end.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-23-2013   #7
Dave
Quark would be so proud
Old 01-24-2013   #8
Pete
Pete's Avatar
Just remembered the loom clip could also be for the harness that runs along side the driver side fender well that one of the fender well screws goes thru it.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
