Old 10-13-2012   #1
tf95ZR1
tf95ZR1's Avatar
Default Clutch Kits
FYI
Amazon.com has a sale on Z Clutch kits.
1990 - 93.5 LuK
Check it out
Old 10-13-2012   #2
Default Re: Clutch Kits
That's a decent price on an LT5 clutch kit.
Question:
Do clutch kits from a standard corvette work with a ZR-1? (I thought they were different?)
The kit say's it works on the standard corvette and ZR-1.
Old 10-13-2012   #3
Hammer
Hammer's Avatar
Talking Re: Clutch Kits
Question:
Need to use shorter pressure plate bolts if you want the car to move after the install. Don't ask.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I]
[I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I]
[FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT]
[I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B])
1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I]
Old 10-13-2012   #4
John,
the throw out bearings are the same too?
thanks
Old 10-13-2012   #5
Hammer
Hammer's Avatar
I would assume so, althought the transmissions were different so some investigation would be in order if someone were to order one. Might call Marc to verify.
Old 10-14-2012   #6
scottfab
scottfab's Avatar
Only the input shaft is different on the ZF6 for the ZR-1
Scott
Old 10-14-2012   #7
Pete
Pete's Avatar
Pros:
All parts will work pressure plate,throw out bearing,clutch disc etc, of the same model year 1990-1992 and 1993-1995
Cons:
You need the LT1 pressure plate screws i have the GM part # just not at this moment.
The pressure plates friction plate (not clutch disc) is thinner then the LT5 friction plate.
I have installed these and they drive normal but if your going to do some heavy duty racing i would think the thinner friction plate might build more heat then the LT5 thicker plate.
Otherwise good to go.
I can rebuild the stock LT5 pressure plates.
Do not throw them out.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-14-2012   #8
tf95ZR1
tf95ZR1's Avatar
Pete you rock
Old 10-14-2012   #9
QB93Z
QB93Z's Avatar
Pete
I have a small stack of used pressure plates in my garage if you ever need cores.
