10-03-2012 | #11 |
Re: Battery Relocation
Has anybody used or know of someone that used one of these.
Looks like it has enough CCA and only 5 lbs. http://www.shoraipower.com/p-210-lfx36l3-bs12.aspx Bob, i like the switch i need to get one of those. Pete
10-03-2012 | #12 |
This one is 4.5lb seems to have all the right numbers.
But one number is bad. $1000 http://lithiumpros.com/products/more...rt_number=L680
10-03-2012 | #13 | |
Just a thought... P.
10-03-2012 | #14 | |
Next time I have it out I'll have to weigh it. And get a pic. on edit here's a pic! Next one I was able to get the reversed case so the leads are at the top. Batteries Plus rocks! Cheers, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] Last edited by batchman; 08-10-2013 at 02:06 PM. Reason: added pic |
10-04-2012 | #15 |
The new Lithium batteries are looking promising - still lacking reserve capacity for street use though. I think I will leave a little extra height in my bracket so it will be adaptable for then this technology arrives.
10-04-2012 | #16 | |
Cost would be $4k Even with two lithiums you'd have ample capacity at $2k. Still prohibitive cost wise. The promise of "lithium-air" batteries is on the horizon. Once/if they are perfected they're expected to have 5 to 10 times the capacity of current lithium batteries. That is said to be the tipping point for electrics to replace gasoline since 500mi range cars would be possible. OOPS of topic but would make for a nice poll.... hmmmm
10-04-2012 | #17 | |
10-25-2012 | #18 |
So here is my battery mount/box which will attach to the rear cross-member. More pics when I get it back from powder coating.
10-25-2012 | #19 |
Where is the hole to drain the road water out?
If standing water gets high enough (on a long wet drive) the terminals will develop a current leakage path between themselves. Depending on how contaminated the water is (conductive) it could drain your battery over night. It does rain occasionally here in the NW
10-26-2012 | #20 |
Well the box will hang with the battery on its side and the terminals will be near the top, backside of the box is closed and will face forward on the car so I doubt much water will get into the box. So... not sure if a drain hole will be necessary.
