Old 09-20-2012   #1
robbz28
Default Tapping noise from engine.
hen i crank up my car there is a distinct tapping noise that sounds like a lifter ( trying to give a comparison for sound) it does increase with rpms but gets unnoticeable after about 1200 rpms. I need to run the engine a while and let it get up to operating temp to see if it remains. Any clues? Is this a "normal" sound for these engines? Its not real loud but you can hear it clearly at idle tat-tat-tat-tat-tat...
[SIGPIC][/SIGPIC]
1991 ZR1 #144 421 rwhp 392 rwt
2012 Toyota Tundra Crewmax 4x4 5.7 liter
1967 Ford Mustang resto-mod coupe 289 (Sold)
robbz28 is offline   Reply With Quote
Old 09-20-2012   #2
scottfab
scottfab's Avatar
Default Re: Tapping noise from engine.
When was the last time the oil was changed?
When mine starts making a ticking (upper eng) sound it's telling
me "it's time" . I go beyond the "change oil" notice on the dash.
Scott
Old 09-20-2012   #3
tpr60
I had the same noise. Talked to a bud who builds race motors, he said to warm up motor to operating temp alowing it to idle. Noise should decrease as engine temp comes up. My noise went away. Cause/ oil bleading out of a lifter after extended non use of car, 6 months. Hope this helps!!!
tpr60 is offline   Reply With Quote
Old 09-20-2012   #4
robbz28
Im going to let it warm up see what that does. And i JUST changed the oil last week...so ill see when i get home.
[SIGPIC][/SIGPIC]
Old 09-20-2012   #5
scottfab
scottfab's Avatar
You may have sticky lifters from build up.
When I first got mine I had to use an engine flush.
It's basically a quart of diesel fuel that is run for 20min?
Can't remember.
Then you drain and fill with fresh oil.
Scott
Old 09-22-2012   #6
robbz28
Well i think my car is ok. Must be sticky lifters. I cranked it up today and no noise and got her up to 150...quickly hehe...was a good day.
[SIGPIC][/SIGPIC]
Old 09-23-2012   #7
scottfab
scottfab's Avatar
Glad it's sounding better. One word of caution.
If there is a next time..... check the oil pressure !
If the oil pump is beginning to fail and you see low pressure
when the noise occurs, shut down and pull over.
There have been stories of same.
Scott
Old 09-24-2012   #8
robbz28
My oil pressure is great, maybe a little too great. Since lingenfelter turned it into a 368 they said to use 15w-50 synthetic...I thought that seemed a little heavy, but I'm not going to argue with them. My oil pressure probably stays around 70. I watch it closely, need to get me one of those sweet little shift lights so I can keep an eye on my gauges a little better and not worry about my RPM's so much.
[SIGPIC][/SIGPIC]
Old 09-24-2012   #9
Yeah, one of the slickest ones I've seen is the little Raptor light. It is about the diameter of a ballpoint pen, and about 2-1/2" long.
By removing the vent grille (two screws) and drilling a hole in that flat area to the left side of the grille, the little light can be inserted there out of sight. But, believe me, you'll not have any trouble seeing it in broad daylight!
Easy to set up and just a couple wraps of tape around the barrel wedges it in place to stay until you want to adjust it, which only requires it be pulled out an inch or so to access the "click" dials.
In the picture you see it giving me the "Hello! I'm ready!" signal at power up. When you make a setting adjustment or change to same, it will first flash the 1000s rpm setting, pause, and then flash the 100s settings. 7 flashes, pause, one flash and I know it is now set for 7100 rpm (which seems to work out pretty well for me and my setup).
P.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-24-2012   #10
15-50 ? That's some heavy $hit !
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
