08-15-2012 | #1 |
The Skunk is in the hospital...
Wish me luck...hope I don't have to sell a kidney to get it out!!!
[SIGPIC][/SIGPIC]1991 ZR-1 #128 |
08-15-2012 | #2 |
Re: The Skunk is in the hospital...
whats the diagnosis?
08-15-2012 | #3 |
Don't know yet.
Developed an oil leak up in the front, passenger side, probably one of those many sensors. And has developed a miss/stumble/stammer, whatever you want to call it. But it doesn't seem to be spark, but more fuel related. Will "hunt" for an idle speed at a stop light sometimes, other times it wants to idle around 1800 rpm, like it has a vacuum leak. And driving down the freeway I could feel it surging at speed, which really bothered me. Totally bummed at this point. |
08-15-2012 | #4 |
On my car, those same problems ended up being
1) leaky oil cooler lines 2) popped off purge solenoid vacuum line 3) injectors (but item #2 was more like the your description) |
08-15-2012 | #5 |
My throttle body does the "hunt for a idle speed" thing until I blip the throttle. Sending it to Marc tomorrow for a rebuild.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 08-15-2012 at 02:58 PM. |
08-15-2012 | #6 |
Sent mine to Marc two years ago for the same problem. Works perfectly since.
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
08-15-2012 | #7 |
Which "hospital" did you send it to??
Sounds like some smallish stuff being bigger than the sum of it's parts. The leak - wouldn't be surprised if it was the low pressure (idiot light) switch. Throttle body prolly needs to be re-bushed or something like that. No worries. You be fine. Da "skunk" will terrorize again! P.
08-15-2012 | #8 |
Very likely stickin throttle like mine earlier this year. Marc repositioned the throttle plates and installed helper spring to make sure it closes.
08-15-2012 | #9 | |
I've done the grease on the plates trick, spray grease on the shaft ends and blipping the throttle all to make it better. The grease only lasts about a week. Runs great right after lubrication though. Taking it off and boxing it up in a few minutes. Shipping to Marc tomorrow morning.
08-15-2012 | #10 |
Tried the "blip" fix, no help. If it was just the high idle it would have me headed toward the throttle body. But the surge/stumble on acceleration and then surging at cruise speed on the freeway has me leaning a different direction.
Injectors have approximately 27,000miles on them as do the coil packs and wires. Mike had just changed all that right before he sold it to me. So, I hope it's none of that stuff. Figure the oil leak is the Low Oil sensor, becuase I keep getting that message intermittently. Don't think she's real crazy about being a daily driver in this Vegas heat, but ya gotta do what ya gotta do sometimes. |
