Old 07-31-2012   #1
94Admiral
Default Emissions Success!!!
Just a plug for Marc Haibeck's new "emissions chip".
I have been on the edge the past several tests, but passed today with flying colors.
My '91 blew a:
34 ppm HC (53 ppm limit)
0.06% CO (0.28% limit)
323 ppm NOx (614 ppm limit)
all well under the Connecticut limits (and well under my previous tests). Hurray! 2 more years before sweating out the next test. Atmospheric conditions were 68F and 70% humidity.
For those who are wondering, the Haibeck 500 package on the '91 includes high flow cats, headers, ported intake and heads, aluminum flywheel. and a Haibeck custom chip. I also run 4.10 gears and a Corsa exhaust.
Not sure what the limits are in other states, but the chip worked great for the test in our wonderful, liberal-minded state.
Thanks again Marc - you are the best!!!
94Admiral is offline   Reply With Quote
Old 07-31-2012   #2
Socalerv
Default Re: Emissions Success!!!
Very good to hear as I purchased the chip a couple of months ago for this coming October.
Socalerv is offline   Reply With Quote
Old 07-31-2012   #3
scottfab
scottfab's Avatar
Very cool now you need to take it to the track and get your times.
Scott
Old 08-01-2012   #4
tf95ZR1
tf95ZR1's Avatar
Wow, that would have even worked here in CA!
Limits:
34 ppm HC
.46% CO
494 ppm NO
It is true, M H rocks!
Old 08-01-2012   #5
94Admiral
Looks like the HC limit would be close for CA....
Marc makes a few recommendations that he sends along with his chip for balancing the HC versus NOx totals. Might be worth letting your NOx creep up a little in an effort to reduce your HC. Engine temp, fuel system cleaner, daytime temp, residual deposits, etc. all factor in to the results.
I was just happy it worked with minimal hassles. A chip swap is so simple.
I have to admit, I was thrilled to remove the emissions chip and put the other old Haibeck chip back in last night....runs like a scalded dog again (does not have the performance with the emissions chip, just in case anybody was wondeirng.....).
I agree, Marc rocks!!!
Old 08-01-2012   #6
Kb7tif
Ol Marc Haibeck stating ahead of the curve
Old 08-01-2012   #7
Paul in VA
WoW! I just sent Marc an email on this exact issue thos mroning. I am way low on my HC and CO but my NO is too high. I am hoping Marc can help as well.
Paul in VA is offline   Reply With Quote
Old 08-02-2012   #8
I might have to hit him up in 2 years if Ca lowers the MAX Nos levels again.This past Jan I barely squeaked by.What we should do is everybody chip in-pun intended- to burn a smog chip and send it around the country to those that need to borrow it then send it to the next guy and so on.Illigal,maybe but Im not tellin.My bone stock 91 at 18,000 miles failed twice before I had to take it to a smog referee.I know of at least 7 cars including mine that have failed and all were within spec before the state lowered the limits 18 months ago.
Old 08-02-2012   #9
Great news Scott! Lou may want to borrow that chip when his car needs to be inspected.
I'm curious. Does CT just use a sniffer in the exhaust? NYS has gone over to that system and scrapped the roller test with the sniffer.
Old 08-02-2012   #10
94Admiral
Tom -
They use dual sniffers in the tail exhaust on the rollers at 25 mph.
Scott
