Old 07-31-2012   #1
roadtrip120
Default Crate Engine LT5 , Id Number Decode Help
I have located a LT5 1993 Crate engine for purchase, but i would like some help decoding the ID Tag on the back of the engine.
Thanks for your help. I wanted to make sure it was a 93 405 hp LT5 before I buy.
10ZUD X307060003
roadtrip120 is offline   Reply With Quote
Old 07-31-2012   #2
Default Re: Crate Engine LT5 , Id Number Decode Help
That's easy enough to do without resolving the code. All 405 Hp engines had EGR. Look for the silver flex pipe running from th RH side of the plenum, right behind the throttle body, downwards to the EGR valve located just forward of the engine mount. There are other visual cues but this is the easiest to see.
The 93 will look just like this one.
Old 08-01-2012   #3
Jagdpanzer
Jagdpanzer's Avatar
According to info I have ZUD is not a valid code for any model year LT5.
The proper place to find engne ID is on the left side of the lower crankcase housing inside of the motor mount as seen here for a 1994 model year LT5.
Following are the engine ID codes for all LT5 model years
1990 Engine Code-(First three alpha digits)
ZSD-non-ac
ZSH-AC
1991 Engine Code-
ZTK
1992 Engine Code-
ZAA
1993 Engine Code-
ZVC
1994 Engine Code-
ZWC
1995 Engine Code-
ZUF
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 08-01-2012   #4
roadtrip120
After looking at the picture , the paper tag is on that Bell housing not the engine. But it clearly show a "10ZUD"
It does have the EGR pipe running down the passenger side front of the motor. So that looks promising but the none matching ID makes me wonder a little.
94- Z-28 LT4 385
10.075 @ 135.6mph 541rwhp/ 463rwtq
M6- Moser 9"- Face Plated T56- Jessel Belt Drive Conversion- XFI- E85
97 WS6 Hardtop
LS1 Swap 507rwhp/ 446rwtq
M6- Moser 9"- C6 ZO6 Brake Conversion- 19" CCW 505A
Old 08-01-2012   #5
10ZUD X307060003
Would that happen to be the $7000 NOS motor on Fleabay?Somebody got a smoking deal on that one.
