Old 06-18-2012   #1
Smile Bling
Just have ta show some of our In-House Talent........(Carter and Lee)
Carter200 Bling
All Aluminum Caps are machined with very close tolerance and fit perfectly over existing caps.
All Aluminum caps are engraved as follows and as shown for the Brake Fluid Aluminum Caps.
1. POWER STEERING FLUID (Steering Wheel Etched)
2. RADIATOR 15 PSI CAP
3. WASHER FLUID ONLY (Wipers Etched)
4. ENGINE COOLANT OVERFLOW
5. BRAKE FLUID DOT 4 ONLY
Old 06-18-2012   #2
Default Re: Bling
I see lots o Bling
Old 06-18-2012   #3
Default Re: Bling
Wow Now that's alot of blingo!!!!!!!!!!!!111
Sweet!!!!!
Old 06-20-2012   #4
Default Re: Bling
Yo Cliff, that looks cool!
Old 06-20-2012   #5
scottfab
scottfab's Avatar
Default Re: Bling
I'm really liking that breather box.
You're neglecting the oil filter. It needs a cover in stainless or aluminum. All it would need is a flat spring inside to hold it on.
Scott
Owner since 1997
Carter200 Bling
Scott
Old 06-20-2012   #6
carter200
carter200's Avatar
Default Re: Bling
Scott
Owner since 1997
I make those, too! Golden Cylon, HawaiiZR-1, and many others have one. Anyone want to post a pic of it on a motor..........Thanks, Carter
PS: No flat spring required
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 06-20-2012   #7
Paul in VA
Default Re: Bling
Hi All:
Great Thread!
Any sources on replacement aluminum tanks for the various plastic tanks underhood?
Thanks ... Paul
(Paul in VA)
Paul in VA is offline   Reply With Quote
Old 06-21-2012   #8
RICKYRJ1
RICKYRJ1's Avatar
Default Re: Bling
I also sport Carter hardware but I pc'd them black and colored in the writing with a silver/red combo. My Coplon is also painted black. Always get big compliments directed at Carters work.
Old 06-21-2012   #9
Default Re: Bling
Dyno,
I would think the BKR 5s are a bit too hot. I run the 6s. Maybe Iridium is different, but it would be interesting to look at the ground strap on those plugs.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-21-2012   #10
Default Re: Spark Plugs
What does the ground strap look like? That determines heat range. BTW, I don't use anti-seize anymore. Always found plugs would loosen up. I just apply a film of oil on threads now.
Hmmmmm.........those plugs are a nice chocolate color
NGK Iridium
With a bit of Anti-Seize
