Old 05-28-2012   #31
VetteMed
Default Re: C4 Chassis Stiffeners from Killebrew
Ricky,
Have the bottom stitch welded before install. Back in 93 I had it installed stock and was not completely stisfied. Took it to Corvette Masters in Maitland, Fl, had Robbie weld plates and close it off - a world of difference.
Great info, Yun. Was the brace dismounted then welded, then reinstalled?
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
Old 05-28-2012   #32
Yes. If I remember correct, at least for the 91 I had at the time, front had holes needed. For the rear, a bolt had to be welded to a plate then the plate welded to the frame.
Dismounted, bottom pieces welded continuous over the "X", effectively making the whole thing one piece, then bolted to the car.
Old 05-29-2012   #33
RICKYRJ1
RICKYRJ1's Avatar
Ricky,
Thanks, I will pass the info onto George B. our WAZOO master metal man.
