Old 05-18-2012   #1
gbmidyear66
Default Plenum Port + Standard Gaskets = Bad Idea
I completed a top end Port in March and have been driving my Z as a Daily driver since (well I also sold my SUV and am waiting for my new one to arrive).
Car has been running great - but in the last week I'm getting a vacuum leak sound and I'm leaking a small amount of antifreeze from the Passenger IH plug (3rd #$%^& time I have tried to seal it with gasket cement).
When I put it back together in March I used a set of standard thickness gaskets I had purchased some time back - I trimmed them to the opening of the port. When I took her apart tonight - the gaskets had literally been sucked inward from the vacuum . I guess trimming them was a bad idea..... Luckily LGAFF (who did my port) had sent me along a new set of the thicker gaskets. I put those in tonight - I hope this is a permanent fix.
I liberally wrapped the leaky IH plug with teflon tape this time - hope this does the trick.
She's running smooth and quiet again.....
[SIGPIC][/SIGPIC]
1990 Corvette ZR-1 #2824
4.10's, Custom PROM, Flowmaster, Top End Port
NCRS BC Chapter
Old 05-18-2012   #2
carter200
carter200's Avatar
Default Re: Plenum Port + Standard Gaskets = Bad Idea
When it's apart again check the straightness of the IH to make sure it's flat. Sounds warped to me............
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-18-2012   #3
Carter, no welding on these or anything only Powdercoating.....as the parts were factory PC'd would not think warping would be an issue
Old 05-18-2012   #4
if the plenum if only leaking around the one runner, I would think the issue is coolant getting under the gasket, not warping....try the tape, and recessing the allen head then covering with RVT
Old 05-18-2012   #5
gbmidyear66
No - its not related to the coolant. The pic of the side I attached (which was worse than the other side) was the side that WASN'T leaking coolant.
Thinking about this more - I am wondering if I created the problem myself.... I glued the gaskets to the Plenum using contact cement, then applied a coat of motor oil to the mating side (since I was sure I'd be going back in again at some point!). I wonder if adding the coat of oil was a bad idea - clearly it will reduce the binding of the gasket to the IH surface?
The gaskets you sent Lee were about 3 times the tickness and didn't need to be trimmed - I am hoping the increased structural rigidity of these gaskets will be sufficient for them not to collapse like the std thickness ones did.
[SIGPIC][/SIGPIC]
NCRS BC Chapter
Old 05-18-2012   #6
mike100
I recently pulled my plenum for a similar reason...no vacuum leaks, but I had cranckcase vent oil seeping across the gasket and oozing out of the side. It bothered me enough to redo it.
Basically I had used rtv silicone gasket seal around the water port and a very thin film around the crankcase breather ports. I think the sealer was so thin it cured before I had a chance to torque the bolts which may have left an uneven texture allowing the oil to weep across the gasket surface.
Following Jerry's advice, I used the brown Permatex aviation form-a-gasket style sealer which doesn't harden up right away. He also sent me the thicker gaskets which I think I prefer, if for anything, they seem less likely to tear.
Old 05-18-2012   #7
mike100
Another factor that may have contributed is if the gaskets got moved around too much while you assemble the plenum top.
I use M6 all thread studs in the 4 corners of the i/h mounting holes. they are only an inch long and act as a guide to drop the plenum on, plus hold the gaskets from moving around.
Old 05-18-2012   #8
rhipsher
rhipsher's Avatar
I'm thinking the same thing. The glue may have dried before you got the gasket in place and it got fugley. I've never used glue before. I've heard of people using a thin coat of grease to help increase the sealing but not oil.
Old 05-18-2012   #9
rhipsher
rhipsher's Avatar
Of course the other method of coolant block off is the finolic plenum spacers that don't have the coolant holes in them. I personally like the idea of just tapping a thread in the coolant hole to block it of myself. Using the spacers is more work and you have to cut 4 gaskets instead of two. But it's always worked very well for me.
I just go down to the auto parts store and just buy a sheet of .062 thick Felpro gasket materiel and I use .048 thick for my throttle body after I top end ported my car. And just use the spacers to trace out the pattern. But I also have the spacers marked face 1-2-3-4 so they go back on the same way I blended them to the plenum and IH housings.
Old 05-18-2012   #10
gbmidyear66
I glued the gaskets (last time and this time) to the plenum. There is no chance the gaskets moved during assembly. You can see the glue residue in my photo. I guess this raises the question of whether the contact cement was a good idea ( I got the idea as a recommendation from somewhere else - can't recall where)
[SIGPIC][/SIGPIC]
NCRS BC Chapter
