Old 12-08-2006   #1
HADI-ZR1
Default what the water colant temp. is when the gauge needle is in center position!?
What the water colant temp. is when the gauge needle is in center position ? i always loved the digi gauges on my 1986 vette with F and C reading.... ! any one know it? thanks
Old 12-08-2006   #2
guinnessdood
guinnessdood's Avatar
Lightbulb Re: what the water colant temp. is when the gauge needle is in center position!?
Well...it doesn't really matter because you can check the ACTUAL temp by pressing the FAN SPEED UP and DOWN buttons at the same time and hold them for ~5 seconds and then use the UP arrow to scroll to 16 on the display...then press the FAN button (the one between the UP and DOWN arrows)...this is the coolant temp in °C. Since you understand °C, there is no need to convert to °F.
So...get your car warm and when it is in the center position do the above procedure...then you will know. :-)
guinnessdood is offline   Reply With Quote
Old 12-08-2006   #3
Default Re: what the water colant temp. is when the gauge needle is in center position!?
Here is the information that shows the temperature value for several points on the 90 ZR-1 temperature gauges.
Scale %...Oil Temp...Water Temp
0%............100..........100
25%..........191...........184
50%..........220...........210
75%..........246...........232
100%........280...........260
Old 12-08-2006   #4
HADI-ZR1
you are talking about arows and up and doen , ?? where all that??
Old 12-08-2006   #5
HADI-ZR1
thankssss alot brother > guinnessdood for mseging me back.
Old 12-08-2006   #6
HADI-ZR1
thanks Tomy too
