Old 04-15-2012   #11
John Boothby
John Boothby's Avatar
Default Re: New Z brother in the ranks
Yes,nice color combo! Like the wheels too. Welcome!
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
Old 04-15-2012   #12
CongratZ! And, welcome to the Brotherhood of the Beast! You came to the right place for all things ZR-1!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 04-15-2012   #13
tomcat
tomcat's Avatar
Hello, Sweet ZR1
Manfred E...........
91 #906
http://pnwzr1.net
tomcat is offline   Reply With Quote
Old 04-15-2012   #14
CJ_ZR1
Thanks guys!
I had been looking for a Z for a few months and when I saw this one so close to me I had to check it out. Car is in amazing shape and Steel Blue Metallic is gorgeous. Car has 55k miles and has been tastefully modified:
- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)
- Nology hot wires and screemin deamin coils
- Fluidyne aluminum radiator and 9 row aluminum oil cooler
- ZR51 Beam Plates
- Fidanza light weight flywheel
- 4.10 gears
- Stainless works SS coated headers
- Borla exhaust with x-pipe
- Poly bushings except for upper/lower front a-arms, DRM trailing arm and camber brackets, lowered 1” (removed/positioned factory shims)
- ASM bolt in 4 point roll bar
- Hurst short throw shifter
Took her out for a Sunday drive:
I hope to meet many of you at The Gathering
CJ Daniel
[B]1991[/B] ZR-1 #834 [COLOR=royalblue][B]Steel Blue Metallic/Steel Blue[/B][/COLOR]
[COLOR=red]Frank Approved ZR-1[/COLOR]
[SIZE=1]- Ported air horn, throttle body, plenum and injector housings (Tommy Morrison)[/SIZE]
[SIZE=1]- FIC SS Injectors / Nology hot wires / Screemin Deamin coils[/SIZE]
[SIZE=1]- Fluidyne aluminum radiator and 9 row aluminum oil cooler[/SIZE]
[SIZE=1]- 4.10 gears / Fidanza light weight flywheel / Hurst short throw shifter[/SIZE]
[SIZE=1]- Stainless Works long tube headers / Borla exhaust with x-pipe[/SIZE]
[SIZE=1]- DRM Coilovers / 32mm front 26mm rear sway bars[/SIZE]
[SIZE=1]- ASM bolt in 4 point roll bar[/SIZE]
[SIZE=1]- 93 ZR-1 Sawblades[/SIZE]
CJ_ZR1 is offline   Reply With Quote
Old 04-16-2012   #15
JThomas
JThomas's Avatar
Looking forward to meeting you at the Gathering. Congrats on the purchase!
Joe Thomas
Corvette Club of Michigan
NCRS-Michigan Chapter Member
NCM Master Ambassador
Former NCM Board Member
1991 ZR-1 Melon Copper Metallic/Black
1992 ZR-1 Bright Red/Black (Sold)
1995 ZR-1 Bright Aqua/Gray (Sold)
2012 ZR1 Super Sonic Blue / Dark Titanium
JThomas is offline   Reply With Quote
Old 04-16-2012   #16
Thats awesome, you should see if you can get tommy to sign it...
Old 04-16-2012   #17
USAFPILOT
USAFPILOT's Avatar
Steel Blue w/ black interior rocks! If I didn't buy a black car I woulda bought one that color combo. Nice mods too. You were lucky to snatch up a good one.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI.
