Old 03-23-2012   #1
efnfast
Default No full power
So I've never really noticed a huge differance between normal power and full power. Seems 125 hp should be pretty seat of the pants. So tonight in 4th gear with power key off. 60-90mph in 7 seconds. Power key on, dash light on. 60-90 mph in 7 seconds. Have I not had full power since I bought this car last summer????? Second gear chirpies is about the best it will do.
Old 03-23-2012   #2
tccrab
tccrab's Avatar
Default Re: No full power
The difference should be night and day.
Depending on your tires and road conditions you should be able to do WAY more than 2nd gear chirpies.
Power Key "On"
Going into 2nd gear at WOT should cause serious clouds of no expense spared super premium Z rated tire smoke.
Hammering the throttle at about 30mph in second gear causes tire smoke with no clutch needed.
Car pulls HARD from 3000 all the way to 7500rpm (and beyond).
Power Key "Off"
Feels like something the wife could drive to the shopping mall in the rain.
Initial acceleration feels good but runs out of wind quickly around 5000rpm.
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 03-23-2012   #3
efnfast
Definatley no tire smoke in second gear. Ever. The good news is, the vette I love I think I'll love more once I get this straightned out. Any suggestions?
Old 03-23-2012   #4
tccrab
tccrab's Avatar
Check to see if any ECM codes are stored.
Does your SES light come on and go off when you start the car?
'Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 03-23-2012   #5
efnfast
SES comes on before I engage the starter, but does not come on when I start the car
Old 03-23-2012   #6
mike100
my car won't spin the tires in 2nd, but if it stops pulling at 5000 rpm, then you are only running on primary injectors.
I don't know of any other way to check outside of the scan tool which shows the sec on/off status.
91-up cars have the green 'full power' led next to the power key. that should illuminate.
Old 03-23-2012   #7
efnfast
MY 90, has a full power display on the info panel. It doesn't seem to stop pulling at 5k. If the scan tool shows seconderies on, does that mean they are working?. Still going to dyno the car tomorrow. Guess that will tell all.
Old 03-23-2012   #8
mike100
if there is a big vacuum leak, the dedicated sensor on the secondary vac line should report a failure as a check engine light. should, never happened to me so I can't step-by-step you through it.
The tech1 tool does have a function to temporarily switch to 16 injector operation for a moment or two for diagnostics, but I do not think it opens the secondary throttle ports.
sounds like yours is working. the engine should run strong from 4000 to 6500..power peaking at about 6k...
Old 03-23-2012   #9
efnfast
Well, like I say, tomorrow I'll dyno it. 250 hp without, 375 with. I'll be sure to post. Should show a little over 300 at the rears?
Old 03-23-2012   #10
1990 quasar blue
Most put down either side of 330. Mine only made 320/320.
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
