11-22-2006 | #11 | |
Re: Brake Fluid
11-22-2006 | #12 |
Re: Brake Fluid
I've got speedbleeders on the calipers now that I've just done the brakes, so it'll be easy to do the brake fluid at least once a year, more often if it needs it.
11-22-2006 | #13 |
Re: Brake Fluid
Thanks for all of the replies. Sounds like I will be going with the Valvoline
Syn. I think that the book says 1 quart will do for bleeding but I'll pick up a couple to be sure. Thanks again
Bob Anderson 1990 #2405 White/Gray Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported Minnesota State Director Founding Member #19 |
11-22-2006 | #14 |
Re: Brake Fluid
I have never needed more than one quart to get clean fluid coming from all four calipers.
11-23-2006 | #15 | |
Re: Brake Fluid
11-23-2006 | #16 |
Re: Brake Fluid
gottcha - 1 qt only - thanks...
11-23-2006 | #17 |
Re: Brake Fluid
hope this is ok do any of you use a power bleeder if so what type. Is there anything special to do when bleeding this car?
