01-15-2012 | #1 |
OBX Install Minor Issues
Test fitting the headers today and only had two small issues.
1) Need a O2 sensor extension for the passenger side. Got one...Thanks Ted 2) #1 tube making contact with steering shaft. Need to dimple a tad! View from the bottom. View from the top. Last edited by Shrek; 01-21-2012 at 08:30 PM. |
01-16-2012 | #2 |
Re: OBX Install Minor Issues
After a good nights sleep, I have a thought! Wonder if I can loosen the single nut on each motor mount perch and pry the motor over enough to clear it. Just need to see how much room I have between the passenger header and the frame. I seem to recall about a half inch while I was test fitting them yesterday.
01-16-2012 | #3 |
Marc Haibeck sells O2 extensions for a reasonable price.
My Jeal headers contact the steering shaft. I improved (though did not cure) the situation by using a couple of alignment shims under the driver's side motor mount. Loosen the lower mount bolts, jack up driver's side, slip shims in, tighten bolts, drive car to let mounts settle. I did not cure the issue; on right turns the shaft still rubs on the #1 primary tube. I plan to add another shim the next time I have the car up in the air again.
2004 Z06/Z16 LeMans Commemorative Edition 1991 ZR-1 #302 White/Gray (sold) 1991 ZR-1 #1147 Red/Saddle (sold) |
01-19-2012 | #4 |
Lifting was not an option! I dropped the angle braces and the mounts are all the way to the right in the slots, so no more adjustment that way. I was able to dimple the tube, well actually more of a crease than a dimple, and all is good.
01-19-2012 | #5 |
Glad to to hear you got it sorted out. These cars must have some production variations. Interesting that mine bolted up w/ no rubbing against steering shaft.
01-20-2012 | #6 |
Shrek, did you dimple the header tube while installed on the motor? Or did you remove and dimple it?
01-20-2012 | #7 |
01-21-2012 | #8 |
01-21-2012 | #9 |
01-21-2012 | #10 |
did you also change the exhaust when you did the headers ? do you have before dyno runs so you can see the improvement ?
