Old 01-15-2012   #1
Torchred96
Default Silicone di electric grease for Injector o rings?
Cliff advised to use white grease to make putting in and removing the injectors easier..but I don't have white grease. i do have regular marine wheel bearing grease and Di electric grease. Can I use either one of these without fear of messing up an O2 sensor?
Sam
1991 ZR-1
:salute:
Torchred96 is offline   Reply With Quote
Old 01-15-2012   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Silicone di electric grease for Injector o rings?
Go with the dielectric grease
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 01-15-2012   #3
Route 66
Route 66's Avatar
I was about to ask the same question, if to use and what to use. I just got to that point today. While I've got the plenum, can you or anyone tell me where I should get new secondary port vacum actuators? I thought I would replace them while Im in there. Thanks E..
Route 66 is offline   Reply With Quote
Old 01-15-2012   #4
I recommend using plain engine oil on the fuel injector o-rings. I see no reason to introduce silicone where it can come in contact with fuel or oil. Whether it's actually harmful to O2 sensors, I can't say from personal experience...... But why chance it when oil works quite well and not harmful.
Likewise, if grease is needed to hold an o-ring in place, use petroleum grease. no harm, no foul.
Old 01-15-2012   #5
Torchred96
Thanks Phil. Love the quick answers to all my dumb questions...but I guess the dumbest question is the one you don't ask. Di-ectric it is.
E, I don't know where you can buy them, but from all I have read, it's more of a headache to keep them then to get rid of them. I made the decision to buy Marc Haibeck's chip and once and for all get rid of that system. Hopefully it will prove to be the right choice.
Good luck...be careful with that While I'm in there..its addictive!
Sam
1991 ZR-1
:salute:
Old 01-15-2012   #6
Torchred96
Jerry, since they're your O rings, I'll use oil. thanks for getting them to me so quickly too.
This forum and people like you have been invaluable in my little project.
Sam
1991 ZR-1
:salute:
Old 01-15-2012   #7
72ZR1
I used FIC injectors they recommend using palmolive soap to install. http://www.corvetteinjectors.com/instructions.html
72ZR1 is offline   Reply With Quote
Old 01-15-2012   #8
Torchred96
Wow, those did not go in easy. ..even with the oil!
Sam
1991 ZR-1
:salute:
Old 01-15-2012   #9
Route 66
Route 66's Avatar
Thanks for the help. Your right it is!
Old 01-16-2012   #10
An assortment of metal picks comes in ever so handy to remove and then install those little buggers. Several shapes come in a little kit. I got mine at an auto parts store.
I used petroleum jelly out of habit.
Pete likes KY jelly, apparently. The rule is, whatcha see in Pete's garage, stays in Pete's garage! So, th-a-a-a-a-ts all I'm gonna say 'bout that.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
