Old 12-08-2011   #1
Scrrem
Scrrem's Avatar
Default Oil Cooler Lines
Long shot, but anyone have an extra set of the steel braided oil cooler lines that were part of that group buy that was done a couples years back?
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-08-2011   #2
Default Re: Oil Cooler Lines
Marc H sells them @ a reasonable price.
Old 12-09-2011   #3
In stainless Steel ? Hmm I dont see it on his list of products? As requested only ?
Old 12-09-2011   #4
phrogs
phrogs's Avatar
I have these lines
JOHNNY P
Currently own
Old 12-09-2011   #5
Scrrem
Scrrem's Avatar
Johnny, those look like nice lines but I really want stainless briaded. I should have got a set during the buy
Rich
Ron Davis Radiator
Old 12-09-2011   #6
PhillipsLT5
PhillipsLT5's Avatar
I know Marc used to sell them, I do not see them on his site now, worth a email to him?
Old 12-11-2011   #7
Aurora40
Aurora40's Avatar
Depending on which group buy it was, you might have been frowning harder if you had gotten in on it...
Marc used to buy leaking lines for $50 and rebuild them. I don't know if he still does. I have the leaking original lines from my 1990 if you want to get them rebuilt and have a fair price in mind. It's the block that connects to the oil cooler that I believe is the "valuable" part.
Someone in WAZOO had the lines rebuilt in like Gaithersburg, MD or somewhere fairly local?
Old 12-11-2011   #8
carter200
carter200's Avatar
Now if Carter would machine the aluminum adapter manifold (with "0" rings) that fits on the oil cooler..........
Send me a sample and I'll make some.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 12-11-2011   #9
limey
Take your pick.
http://www.whiteracingproducts.com/i...oducts_id=1001
I also have about 40 of the blocks in stock for $65.00 each if you want to make your own lines.
limey is offline   Reply With Quote
Old 12-11-2011   #10
Scrrem
Scrrem's Avatar
Now if Carter would machine the aluminum adapter manifold (with "0" rings) that fits on the oil cooler...........the lines are very easy to make up in SS braided using reusable fittings and SS braided hose available from Summit and other places
Just buy Johnny's lines and replace with SS braided hose and fittings
Kurt has the Aluminum adapter manifolds for $65.
1. Use two 10 AN Stainless Steel Braided hose.
2. use two AQP Hose, 90 Degree, -10 AN Hose to Female -10 AN, Aluminum, Nickel Plated.
3. Use two AQP Hose, 45 Degree, -10 AN Hose to Female -10 AN, Aluminum, Nickel Plated.
4. Use two Stat-O-Seal, 5/8 in Inside Diameter, Aluminum with O-Ring.
5. Use two 5/8" JIC x #6 SAE fittings threaded into the Aluminum adapter manifold.
6. One 6mm x 1.0 x 35 mm SS Allen head bolt.
7. One 6 mm SS washer.
8. Two "O" rings for the Aluminum adapter manifold to oil cooler interface.
The first four items can be found at Summit Racing. The fifth item can be found at Discount Hydraulic Hose. Google and shop around for the best price.
In the 6th post of Solutions you will find the instructions for making your own SS Braided hydraulic lines with reusable fittings http://www.zr1.net/forum/showthread.php?p=91379
That's the ticket!! I have an old OEM that I have that was leaking, if I just get the hose and fitting above, I sould be golden!!!
Thanks!!
Rich
Ron Davis Radiator
