Old 12-01-2011   #1
cvette98pacecar
Default JT red ZR1 for sale.
Shaheen has JT ZR1 for sale.
http://cgi.ebay.com/ebaymotors/RARE-...#ht_500wt_1182
Old 12-01-2011   #2
Kb7tif
Default Re: JT red ZR1 for sale.
Lots o miles
Old 12-01-2011   #3
Blue Flame Restorations
Just broke in.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 12-01-2011   #4
109,000 miles...still plenty to go
Old 12-01-2011   #5
cvette98pacecar
14,000.00 with a ride control issue, They are smoking crack.
Old 12-01-2011   #6
it could be something as simple as having to drive the car. or it could be more...i didn't read the listing that close
Old 12-01-2011   #7
tccrab
tccrab's Avatar
Price is uber-high for a fairly high mile car with potentially very expensive FX3 problems.
No offense intended to the PO of the car who's a member here.
I'm sure it's a good car, but quite honestly the market has tanked and this car could wind up costing the new owner $$$ to get the ride control light to go out.
Lower mile cars with no check lights lit are readily available, and some even cheaper than the listing price of this car.
The easiest, cheapest way to get the bulb to go out would be to remove the offending bulb from the DIS, but would still store codes in the ECM/BCM.
Might make it difficult come SMOG time, lord knows what goofy shite the SMOG nazis would fail you for.
This example is more inline with "damaged goods":
http://www.zr1.net/forum/showthread.php?t=16099
TomC
'Crabs
Old 12-01-2011   #8
cvette98pacecar
TomC
'Crabs
My thoughts exactly, The only benefit is there is no pollution testing in Michigan. I offered them 9500,00.00 out the door "as is". I figured it could be a driver until it needed a big displacement engine.
Old 12-01-2011   #9
mike100
a ride control fault light won't fail the emissions test in Cali. But yes, the FX3 can be as little as a $400 shock rebuild up to having to replace everything for $$$ or pulling the bulb and running regular shocks (also $$$).
If you took $1500-$2000 off for tires and suspension repair, it might be a good ride for somebody who knows C4's.
Old 12-02-2011   #10
cvette98pacecar
It would be a great driver for about 10k. It is at a Chevrolet dealer so why wouldn't they fix the Suspension? The reason is it probably needs an entire rebuild which would add another 2K to the price tag.
I love dealerships that have no clue what they have or what it is worth.
