Old 10-25-2011   #31
USAFPILOT
USAFPILOT's Avatar
Default Re: Monday is "Z" Day....
NOS!!!! Now you need to find the bottle!
Old 10-25-2011   #32
ZONER 95
What bottle????
ZONER 95 is offline   Reply With Quote
Old 10-25-2011   #33
jrd1990zr1
jrd1990zr1's Avatar
Nitrous boost??
1968 convertible Lemans Blue,
1986 coupe Medium Blue NCRS Top Flight (sold),
1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold),
1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018,
2003 Anniversary Red Convertible (sold)
Old 10-25-2011   #34
Originally Posted by ZONER 95 View Post
What bottle????
the bottle that holds the nitrous oxide that your car may have had in the past
Old 10-25-2011   #35
Didn't want to post this before.
Pull your plugs. Note what brand and heat range the plugs are. Number each plug to the proper cylinder and READ each of the plugs. If you have any problem reading the plugs take pictures of each one and post them here.
Good news is if the NOS was applied correctly. And it may well have been , there will be no problem.
Old 10-25-2011   #36
ZONER 95
Must be part of the alarm.....I just emailed the seller for answers......I highly doubt the original 73 yr old owner would have installed nos in a 3k mileage car....
Old 10-25-2011   #37
you'd be surprised by the people i've seen spray their low mileage cars.
but with that "key" switch i'm going to assume it's an alarm, honestly i'd prefer it to be spray. those after market alarms can be hell
Old 10-25-2011   #38
USAFPILOT
USAFPILOT's Avatar
i agree...it is most probably an alarm system, but you will want to find out either way. Hell, if that NOS system is still in there it could be a ton of fun. There seems to be two switches and 4 lights. I'd be real curios what each light meant. Could it be a dual stage NOS system 9two (red LED's) system powered (white light) system spraying (green light). I am just guessing. Most alarms don't have all those lights. Is there a shift light on it somewhere? I once saw a kit that puts a little shift light in you air conditioning vent above the radio.
Old 10-25-2011   #39
it would have to be a really small bottle to still be hidden.
Old 10-25-2011   #40
USAFPILOT
USAFPILOT's Avatar
i there was a system you may on;y find the fittings and lines. The bottle could be gone.
