![]() Join Date: Sep 2011
I got my amsoil z rod in today and will get a filter tomorrow. How many quarts will it take? ( not flushing the system ) , It had amsoil all along and I figure I'll keep it that way.. Thanks
About 10...give or take
![]() Join Date: May 2007
For an oil change with a filter change I add 8.6 quarts.
Jim |
I only get 8.5, would be nice to get out 10
maybe it is around 8...been a while since i measured it
Just a suggestion... I would put in 8 qts and start engine briefly and then check dip stick and then add 1/2 qrt at a time (start engine and shut down) until dip stick shows correct level. Engines with oil coolers etc can be tricky and it is better to slowly step up to oil capacity rather than over fill. BTW...most excellent choice in oil
wait 24 hour to drain down before check
![]() Yep the SM says too most dont ![]()
I'll do the 24 Hr wait .. Does anyone here use Prolong or Dura-lube..? I would think it would help with the first few seconds of starting....
#10 |
You'll be one of the few who do. No need to over think this one. You're already putting in top-of-the-line fluids. I'm not certain how much you're going to gain on this one.
