Old 10-09-2011   #1
key_on
Default Battery cable question
The threads on the threaded bolt on my negative battery cable appear to have worn down to the point that the cable cannot be held tight against the battery. Is it possible to replace the bolt or will I need to replace the entire negative battery cable? Any thoughts are appreciated.
key_on is offline   Reply With Quote
Old 10-09-2011   #2
Mr Cool
Default Re: Battery cable question
You can buy replacement bolts at the auto parts store. I just replaced both of mine the other day.
________
90 white/grey #2011
Mr Cool is offline   Reply With Quote
Old 10-09-2011   #3
Aurora40
Aurora40's Avatar
It can be a little annoying to get the bolt out of the plastic (actually, it's more annoying getting the new one tucked into the plastic), but they are replaceable. If you can't find one at an auto parts store, any GM dealer should have them for a reasonable price.
Bob Saveland
Former owner of #2517
Old 10-09-2011   #4
Concur grand total $1.99 real easy to do
Old 10-09-2011   #5
key_on
Thanks to all who replied. I was hoping that there was an easy solution.
Old 10-10-2011   #6
Torchred96
I havent looked at mine specifically but usually, i just put a little oil or wd40 on them and they pop out and back in much more easily..if you don't, they can fight ya.
Sam
1991 ZR-1
:salute:
Torchred96 is offline   Reply With Quote
