Old 09-28-2011   #1
Don in VT
Default Measurement of stock alternator housing
Greetings to the Forum
I need a favor from someone on the forum. I need the diameter measurement of the alterator housing on a stock alterator from a 1990 ZR. If someone could measure the diameter of the rear of the housing and let me know what it is I can be sure if my new unit will fit.
Many thanks,
Don
Don in VT is offline   Reply With Quote
Old 09-28-2011   #2
Default Re: Measurement of stock alternator housing
5 5/8" is what I get when I measure the back side with a tape. That is not using the ears that are for the bolts that hold the front & back sides of the case though.
If I use my digital slide ruler I get 5.6".
This is a 91 alternator, it's my spare. I do think that all the LT5's use the same alternator?
Old 09-28-2011   #3
is your new unit from a LT1/4? if so it will not fit
Old 09-28-2011   #4
Don in VT
Hi TomTom,
Thanks for the measurement. My alternator measures the same.
Regards,
Don
Old 09-28-2011   #5
Don in VT
Hi Jeff,
Thanks for the heads up on the LT1/4 aternators. Could you get back to me with just what the difference is, in alternators, between the LT5 and the LT1/4?
Regards,
Don
Old 09-28-2011   #6
Case size. The LT1/5 have a larger case then the LT5 does
Old 09-29-2011   #7
Amps are different as well
Old 09-29-2011   #8
Don in VT
My case appears to be the right size @ 5.6 in. I just hope the mounting ears are in the right place. The electrical seems to be OK. The pulley diameter is a bit larger so I will have to pick a longer belt but that is no big problem.
Thanks for the help
Don
Old 09-29-2011   #9
a1991zr1
yo know you can reclock the alt if the ears dont line up and also change the pulley to your old pulley fyi
a1991zr1 is offline   Reply With Quote
