Old 09-28-2011   #21
Default Re: WTS StainlessWorks Ceramic Coated Headers
Originally Posted by tf95ZR1 View Post
Interesting. Both an X pipe AND a resonator.
Must be pretty quiet.
I have this setup. Watson headers and the MF Xpipe w resonator. It works very well, has a deep mellow sound and very little to no drone at ~ 1600rpm.
Old 09-30-2011   #22
sammy
is the x pipe and resonator 3 in or does it neck down to 21/2 in at the resonator?
Old 09-30-2011   #23
It does neck down at resonator. Paul W did a fairly extensive measurement of MF resonator. However, this is the setup I used both to run 118+ trap speeds and dyno ~400rwhp. I'm planning on dyno tune on the 14th again with same setup. We'll see. The Corsa setup is smaller than the MF system and Haineck thinks the Corsa doesn't restrict.
I'll keep u posted.
Old 10-02-2011   #24
Ccmano
Headers are SOLD....Thank you 93RubyZ... X-Pipe will be listed again separately ...
H
