Old 09-27-2011   #1
Default Bleeder Screw Question
I want to replace the bleeder screws on my front calipers and I'm having trouble finding an exact replacement. What I've purchased from AutoZone and Corvette Central don't match -- the threads are longer for starters. Any problems using the ones from CC? Anywhere I can find originals?
Stuff like this should be simple but never is...
Thanks,
Old 09-27-2011   #2
a1991zr1
Default Re: Bleeder Screw Question
Gm dealer is going to be your only bet. however it makes you feel any better I used the ones from autozone about two months ago and had no problems
[B]"the winner ain't the one with the fastest car its the one who refuses to lose"
- Dale Earnhardt
:saluting:
a1991zr1 is offline   Reply With Quote
Old 09-28-2011   #3
Cool. I'm not a stickler for "correct" but it has to work...
Old 09-28-2011   #4
gbmidyear66
I am in the exact same situ. Bought replacements from NAPA on Monday - they look like the corvette central ones.I did see that Corvette Specialties (I belive) had them on their site -and they looked like an exact match to original
Yeah - one of mine looks just like yours....
Glenn
[SIGPIC][/SIGPIC]
1990 Corvette ZR-1 #2824
4.10's, Custom PROM, Flowmaster, Top End Port
NCRS BC Chapter
Old 09-28-2011   #5
These appear to be the correct screws. I'll order a set and see if, in fact, they match the originals...
RAYBESTOS S23925 Brake Bleeder Screw
Old 09-28-2011   #6
a1991zr1
they will work but are longer it however makes no difference
- Dale Earnhardt
:saluting:
Old 09-28-2011   #7
gbmidyear66
Corvette Specialties -CA-34165 84-99 Caliper Bleeder Valve
Appears to be the exact match if you want to go that way
[SIGPIC][/SIGPIC]
NCRS BC Chapter
Old 09-28-2011   #8
Thanks!
Old 10-01-2011   #9
gbmidyear66
A word of advice....
Don't use the Raybestos screws. I picked up those to replace my OEM's which where a bit banged up. Well, I simply could not bleed the caliper effectively with these screws (using my hand vacuum pump). The holes in these screw are smaller than OEM. I either got no flow, or lots of air. The stock screws worked fine.
[SIGPIC][/SIGPIC]
NCRS BC Chapter
Old 10-01-2011   #10
a1991zr1
i had no problem with mine but i gravity bleed then manually finished each wheel also just re didi bais spring in the master cylinder made a hell fo a difference.
- Dale Earnhardt
:saluting:
