07-29-2011 | #21 |
Re: New Owner #1581 White/Red
Thanks for the links David and Thanks for the comments everyone.
After seeing the car in person, I was prepared to bid 12k for the car and that's the number I bid. Imagine my surprise when it didnt break 9k and there was NO reserve. I had to pinch myself. The seller actually got the car for 6k at auction as I recall, so he didn't lose money. I didn't notice the noise until I got home and did a hot restart...and heard that dreadful knock...HORROR struck until I read some posts on here that set my more at ease. I can't wait to start getting my hands dirty. Kind of afraid to drive it too much because of the noise. Don't want to cause damage by running it lean.. if it's not already damaged. I will be looking to you for you help in the near future. Thanks again! Sam |
07-29-2011 | #22 | |
service wheel sensor light comes on. I'm not sure if it works the same for your car but on my 90 I can just yank all 4 sensors and not have a problem. will have to wait for verification service engine light stays on. Pull the codes and let us know what they are KNOCK at idle when car is warm. This goes away just off of idle. It also appears to have coincide with a miss. Scared the crap out of me first time I heard it.. Sounds like a rod knock..but I thought that would be at all rpms instead of just idle. injectors plugs wires...it's one of the three stumbles on acceleration. secondary pump not turning on secondary not holding vacuum (going to the engine) you've got a vacuum leak Paint on back bumper is slightly yellowed and theres a 4" scratch on the left corner of the bumper. Paint overall is acceptable, but definitely not what she deserves. find a good detailer in your area...autopia.org has a list, if not let me know and I'll see who i can find for you. also noticed that your motor is a little dark, and you're missing the rear plate frame I'd keep an eye open if one pops up for sale. it happens with age but if you feel froggy you can get it redone. Sorry I can't help you with the rest.
It's not the car, it's the people - Doug Johnson 90 r/r "KEYS ON" nick named "T.L.B" Last edited by Kevin; 07-29-2011 at 06:12 PM. |
07-29-2011 | #23 |
^^^ yeah, the knock could be a side effect of an old injector or ign. miss coupled to the usual wear and tear associated with the dual mass flywheel. It sounds terrible if the idle is rough. does it knock a tad when you turn off the engine?
Mine went away when I put in new injectors. |
07-29-2011 | #24 |
Kevin, you're making this too easy for me...I'm a rookie, I'm supposed to get some hazing and earn my wings..
You are too kind. I can't wait to get home and start addressing some of the issues. Yeah, that license plate really bothers me. Are there any options that look good short of finding an original frame? I like the idea of redoing the plenum. I am going to tackle that when I do the injectors. The door switch is definitely the problem with the light..it goes off as I pull the door handle closed tight when i drive down the road. I didn't realize it was adjustable....cool! thanks sam Last edited by Torchred96; 07-29-2011 at 06:07 PM. |
07-29-2011 | #25 |
Mike...There are a few noises. One is a rattle at shut down the other is more of a knock, not like the bad gas rattle when you accelerate, but a single knock that coincides with the miss, and it's only at idle. Scary sound.
As I said though, If I bring up the idle a little to around 1200 (im guessing with no tach), the knock goes away completely and the engines smooths out with no unusual noises. thanks for you input. sam |
07-29-2011 | #26 |
see how close you are to south georgia corvettes. aaron will take care of ya, but it may cost ya
07-29-2011 | #27 | |
you could try pulling a plug wire to see if the knock follows that..it should get worse. a bearing problem usually gets quiter when removing the ign from the cylinder in question. External sources would be louder running on 7 holes- easy to check. |
07-29-2011 | #28 |
Good info mike, I'll try removing the plug wires one at at time and see if that knock rears it's ugly head. What causes the knock if it is indeed a spark miss. It doesn't make sense to me..I can see preignition would do that, but with no spark, there'd be no ignition, let alone preignition, right? hmm
sam |
07-29-2011 | #29 |
Welcome to the club. I like the white/red combo.
I got mine with 80,000 and have replaced the plugs, wires, coils, and injectors. I can highly recommend FIC for injectors if needed. I have the stainless steel set and got all of my soft parts from Jerry's Gaskets also comes highly recommended. You will find that everyone here is very helpful and friendly. So just ask away and standby for plenty of help.
1991 ZR1, White/Red. |
07-29-2011 | #30 | |
