Old 07-19-2011   #11
Blue Flame Restorations
Default Re: Big Brakes Needed
Brett,
You need 18" wheels for the Z06 calipers. Won't work on 17s. I'll sell you my Brembos and convert to Z06 brakes.
Man, that sucks! I'd hate to think I'd have to do C5 Z06 brakes. I'm not getting rid of my Dymags though.
I guess I need to look at some Z's with C5 calipers.
How much for the Brembos, Dom?
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-19-2011   #12
Originally Posted by Blue Flame Restorations View Post
Hi all. I want to utilize either C5 or C6 ZO6 brakes. I know there are some caliper brackets and kits. I searched the threads but would just like to be able to take the list for what I want and order it.
I have GenII Dymags that will accept some huge brakes. I just don't know how huge????? They are 17x11 and 17x13 wheels.
I "think???" I want to stay with Corvette brake calipers and rotors, preferably.
Any advice?
Very doubtful you can fit C6 Z06 brakes. (rears maybe, but fronts almost certain they won't fit)
C6 Z06 brakes are very pricey.... If you go "cheap", they are 2k.
C5/C6 brakes are a great value @ under $600.
Old 07-19-2011   #13
I just want to get an idea of what I need to buy next month at Carlisle. I plan on spending some serious $$$ on everthing I need ZR1. I want GM bigger brakes on the 92 project car. It would be nice to buy everything I need while I'm there.
I also need a perfect hood and front bumper assembly.
Old 07-19-2011   #14
What does Bob have on his 427 car?
Old 07-19-2011   #15
Wilwood 6 piston in the front. I think 4 piston in the rear.
Old 07-19-2011   #16
I think he and Al have Wilwoods. I would do the C6Z brakes as a straight up swap for the Brembos. You buy the C6Z brakes and adapters, I'll give you the Brembos w rotors and pads
Old 07-19-2011   #17
I'm contemplating what to do. I just looked at the C5 Z06 calipers on ebay and the brackets for them. About $600 for that setup. Brembos are intriguing though.
Old 07-20-2011   #18
Aurora40
Aurora40's Avatar
Is the adapter hardware for the C4 pricey? Because for $2k you could buy all brand-new GM calipers, pads, and rotors shipped. Used should be considerably less than that.
I've been keeping an eye on them because I have a friend with a C6 in the market for them.
To the OP, it is the 14" rotor diameter and the fact that your wheels are only 17" in diameter that makes them unlikely to work. Not any kind of spoke to caliper clearance.
Bob Saveland
Former owner of #2517
Old 07-20-2011   #19
Aurora40
Aurora40's Avatar
I thought the adapter was like $120ish for C4's. You could probably find used calipers for <$100, rotors can be had for like $25 per from NAPA, and then some Hawk pads for another $100 would put you well under $600.
You can also use C5 regular calipers or C6 regular calipers, to keep your options open when going used.
Is the upgrade for looks? Or for more braking capacity?
Bob Saveland
Old 07-20-2011   #20
AUrora40, thanks. Actually looks and performance. Mostly looks though. I like the looks of a 2 piece rotor, drilled/slotted. I am understanding that a 13" rotor is my max size with the 17" Dymags. I'm ok with that.
May do the brackets and C5Z06 calipers.
