Old 07-09-2011   #11
Default Re: New Acquisition & Questions: 1992 #043
Originally Posted by C4Fan View Post
Hi jcruz from another Florida 91 ZR-1 owner. The ZR-1 Registry was able to help me with a similar decal issue and I'd like to pass the resource along to you. Check out the site http://www.ecsvin.com/index.php and see if you can find your ECU sticker on there. And, let me know if you ever find yourself driving through Jacksonville with your ZR-1.
Awesome! I'll follow up. I graduated from JU! I get back there every now-and-then -- I'll be sure to give you a shout.
Old 07-10-2011   #12
WVZR-1
Using your '91 ECU label as a guide I believe you would find this information on your '92 label. I used some VIN information to get your ECU from the vehicle build information and it's recorded as 8001. I thought that unusual until I used your VIN to get some calibration information. I'm accustomed to seeing the 4 place "letter code" in the build information.
From that I believe you could maybe confirm on your faded "label" maybe the information. I assumed the 16163993 was available in '92 and used for reference. If it's not that it could still be a 1228331 but I have doubts.
LINE 1: SERV. NO. 16163993 --- AYWT
LINE 2: The "numeric" information on the "bar code"
LINE 3: 16168043 (THE ORIGINAL ASSEMBLY ECU)
Perhaps you can let me know how I did! I got the information from here after I identified the 8001 build.
I have no idea how to decode the "bar code" or LINE 2 information but I'd guess it's from the electronics build when assembled and maybe used during assembly line.
The first section of line 2 I'd think is the date code and perhaps the other section the serial number or assembler information.
Here's where I got the information after identifying the build. Go here and enter your VIN.
This is what I assumed your VIN is: 1G1YZ23J1N5800043
http://tis2web.service.gm.com/tis2web
On the first line the identifier 8001 that I got from the VIN build is a match. Keep clicking next and the information drop down!
BTW - The most current PROM for your car looks to be BPPA and I've got an NOS one in the box.
Old 07-10-2011   #13
Didnt like to looks of mine so I made a small cover for it.[IMG][/IMG]
Old 07-10-2011   #14
Blue Flame Restorations
I like the cover, Jeff.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-10-2011   #15
Awesome! Thanks for the info...I checked out the web site. Attached is a picture of the output. Does that match your results? I'm quite a newbie at this and don't have much of an idea what I'm looking at. If I had to guess I'd say you're on the money as far as the original sticker. I'm wondering if the ECU has been replaced?
Maybe somebody can post a picture of their '92 ECU sticker -- I'd like to compare the format...
Old 07-11-2011   #16
PhillipsLT5
PhillipsLT5's Avatar
I like the cover and paint on both pieces
Old 07-11-2011   #17
Cant really do anything with a ratty looking sticker...........SO COVER IT UP!I really like this paint.Its Zolotone Hamlet Black 20-06.
