Old 06-24-2011   #1
Default Clutch Parts: OEM
Met Jim Jandik, guy knows more about flywheels and clutch parts than just about anyone I have met....lots of LT-5 stuff
Clutch Discs; pressure plates, forks, pivot balls......rebuilds and restores OEM hydralic stuff too.....great quality
Dual Mass expert tooo
http://powertorquesystems.com/
Found out 12 degrees of movement is typical in the dual mass
Old 06-24-2011   #2
Default Re: Clutch Parts: OEM
Nice find
What is with the 12 degrees of movement on the DM ?
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 06-24-2011   #3
He had examples of what a bad DM looked like...
1)They will clank/rattle or knock as there is a bearing in the center that goes
2)Warpage..which is easily to find
I asked about what the average movement is for a DM and he said a nomrally functioning DM will have about 12 degrees of play in it.
Also told me why there are no more pressure plates, apparently Valeo moved manufacturing to South America and the factory went belly up anf the hat molds were lost.....so no more, only cheap ones from China...
Old 06-24-2011   #4
If you buy something, tell them Lee from the Registry sent you......he does parts development...maybe he will do some ZR-1 focus if we show an interest.
Old 06-24-2011   #5
My experience with DM's is that knock ,rattle is common. This occurs during very very early shifting or lugging the drive train. Some of the noise may be coming from the trans. Although mine was totally done by Billy B.
Frank Urbo.
Old 06-24-2011   #6
lbszr
lbszr's Avatar
Good info
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 06-25-2011   #7
Thanks Lee! This is a nice connection you found!
Old 06-26-2011   #8
C4Fanatic
Stood and talked to Jim for about 45 minutes myself. Very knowledgeable, learned a lot listening to him. Plus, he's a racer and has a lot of real world experience with what he speaks about. Great guy and a great source of info and parts.=D>
C4Fanatic is offline   Reply With Quote
