09-10-2006 | #1 |
NEED PROPER AIR PRESSURE SPECS FOR MY ZR1? HELP :(
I CAN'T SEEM TO FIND THE SPECS ON PROPER AIR PRESSURE FOR MY TIRES, CAN SOMEONE HELP!
09-10-2006 | #2 |
Re: NEED PROPER AIR PRESSURE SPECS FOR MY ZR1? HELP :(
air specs??does it not say on the tire what pressure is adequate??28-32lbs i believe
ps looking on my tires to see peter |
09-11-2006 | #3 |
It will depend on the tires, but most street tires are 28-32.
Look on the sidewall of the tire, it will tell you. TomC '90ZR1 #792
09-11-2006 | #4 |
GM's PSI is on the door sticker, driver's door edge by the lock mechanism. 35 PSI on my 90. I used a bit less, say about 34 or 33 PSI but found that 35 seems to work better in the twisties after the my D3's get some heat in them.
09-11-2006 | #5 |
THANKS FOR YOUR HELP!!!
09-13-2006 | #6 |
Proper is too much and the tires dont show pressures. Only max.
Mike 427 cu in LT5 [URL="http://zr1mk.weebly.com"]http://zr1mk.weebly.com[/URL] |
