05-20-2011 | #21 |
Re: Thermostat Housing "REPRO"
05-21-2011 | #22 | |
However upon further reflection some things stumbled into my thoughts. What happens if one fails and one doesn't? My correction would be to use the AutoZone "fail safe" stats, they fail 1/2 open. What happens if both do not open & close at a rate say within 10% of each other? On an open deck motor I don't know if that's a good thing. I'm thinking flow restriction out of each side of the block and the resultant PSI build up under each head. I'm thinking steam pockets & turbulence? Not trying to be a wise a$$. Tom Brett, sorry for the Hi-jack.
05-21-2011 | #23 | |
05-24-2011 | #24 |
Thanks guys for your thoughts, I passed them on down the line. Two or more heads are always better then one.
Found a Jag separate thermostat housing similar to the zr1, will let everyone know if it works out. |
06-15-2011 | #25 |
Update
Just an update to the project. I am having the housings cast and machined. The units will look very close to original, afterall. Machining will be performed on the Bridgeport. Once machined, the rest will be pretty straight forward.
More to follow as I progress.
1988 KOH Prototype EX5023 sold 1990 ZR-1 #444 Convertible 1990 ZR-1 Black #966 1991 ZR-1 Quazar Blue #296 1957 Duntov SS Project Last edited by Blue Flame Restorations; 06-16-2011 at 06:19 AM. |
06-16-2011 | #26 |
Way to be Brett!
06-16-2011 | #27 |
Tom, your extra unit is in the pipeline, for all the help and parts you have given me with the 88.
06-16-2011 | #28 | |
You Sir are a gentlemen and a scholar, and a great judge of fine whiskey and motor cars! Thank You! Hey, do you need ignition coils for Elvis? I found my OEM/BG coils that I swapped out from my car? Oh, they work too even at 15 yrs old & about 14k miles. I swapped them when my OE injectors went out to lunch. Tom
06-16-2011 | #29 |
Brett, that's great to hear! it's nice not to have to be in the crosshairs of parts hoarders :-)
2004 Z06/Z16 LeMans Commemorative Edition 1991 ZR-1 #302 White/Gray (sold) 1991 ZR-1 #1147 Red/Saddle (sold) |
06-16-2011 | #30 | |
