Old 04-28-2011   #11
Default Re: Coilover too much spring?
Anyone have a pic of their rear coils. Need to check those out too.
Old 04-28-2011   #12
yes i would get new springs..
but you need to decide on the rates
Im running...425 front/ 275 Rear. Happy
Old 04-28-2011   #13
Dom heres some old pics before the Banski Trailing arm upgrade
Old 04-28-2011   #14
Daniel_Mc
Daniel_Mc's Avatar
The spring is defiantly the wrong one; it is much tighter than it should be. You can get springs and pretty much everything you need from HRP World. http://www.hrpworld.com/index.cfm?fo...ction=category
That looks like the DRM set up with the hat that it has, if I am thinking correctly the EM kits use a different hat much like the Callaway set ups. How high up the sleeve do you have the perch?
Here are the DRM's on the '89 same as everyone's above: (Sorry for the crappy camera phone pictures)
Old 04-28-2011   #15
Might explain the rubbing sound I get on a left hand sweeper. The rear tires are rubbing the inner fender well a bit towards the rear also.
Dom this is why I ditched the rear dog bones and went to the Banski trailing arms. After loading the new Poly bushings into the dogbones they were too fat with the new coilovers. I highly suggest you DO NOT do any alignment work until you are done with your suspension work. I also suggest you think about new trailing arms due to the clearance issues. GC
Old 04-28-2011   #16
Daniel_Mc
Daniel_Mc's Avatar
Just spoke w Randy at DRM. He suggested the 400/275. He described it as a tight ride without being bouncy. I asked about the 425s and he said that if he swapped them after having 400s, I wouldn't be able to tell the diff if i hadn't already known. So if I wanted to stiffen things up a bit, I may try the 450s. If I can get them soon enough, I would cancel my alignment to put these on.
I messed with different spring rates and still run (99% of the time) the 400/275 that DRM originally set the car up with. When I stepped up to a bigger spring the car developed a push at lower speeds but at faster tracks (TWS, TMS) the car responded nicely. Your results may vary depending on the bar set up you are running.
Daniel
Old 04-28-2011   #17
ME TOO
Old 04-28-2011   #18
scholtmj
scholtmj's Avatar
525!
scholtmj is offline   Reply With Quote
Old 04-29-2011   #19
Originally Posted by scholtmj View Post
525!
Too much spring !!!
Old 04-29-2011   #20
That's what mine look like.
