Old 04-18-2011   #1
mgbrv8
Default My car update
Okay alot was done today, cleaned the rest of rear the suspension pieces and installed them, aligned the drive train and torqued down the beam plates cleaned up the exhaust. Next remove the OBX headers make one 1/16th dent to help clear the steering shaft a little more and clean the block and install new gaskets and put on exhaust and put the interior back together and we are done. anything I need to do besides change the oil before start up its been a while in the air and I don't want to do anything to hurt the engine.
Dave
Old 04-18-2011   #2
mgbrv8
Default Re: My car update
I also need to do more cleaning, there are greasy hand prints all over.
Dave
Old 04-18-2011   #3
Blue Flame Restorations
Looks like a lot of hard work done there. Looking great. How do you like the OBX's?
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 04-18-2011   #4
Looking great!
I suppose if you have some time you could pre- load an oil filter while your cleaning up stuff before you get to the oil change. I do three every winter so they're ready for the driving season. Just a fwiw.
Old 04-18-2011   #5
mgbrv8
Thanks tomtom72, what do you mean pre-load a filter if I may ask?
Dave
Old 04-18-2011   #6
carter200
carter200's Avatar
Thank you for posting something about the OBX headers......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 04-18-2011   #7
mgbrv8
I love how they fit, the only thing I am going to do is dent the primary tube that goes near the steering shaft. right now I have a 1/16th of a inch I want another to make it at least a 1/8th.
Dave
Old 04-18-2011   #8
Dave, I pour new oil into my filters ahead of my oil changes. It takes some time to do it. I pour in some & come back to it after an hour and pour in more. The element absorbs the oil and finally I usually have to pour off the last bit as it will not absorb.
I feel at least I don't have a large volume for the pump to fill up upon start up after a change. I'm not sure that this actually does anything useful? I notice that it takes less time to get pressure up ( looking at the gauge ) when I do the first start up after changing the oil.
I know I'm not well!
Old 04-18-2011   #9
Dave
Might not have to do that. On my red 90 the drivetrain wasn't mounted 100% correct. The drivetrain was slightly out of alignment. We corrected that and the header didn't need to be tweaked. This worked for us. Of coarse your situation may be different. Just posting up my experience.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 04-18-2011   #10
mgbrv8
How did you correct it?
Dave
