Old 04-04-2011   #1
Default Little White hose Clip thingy
Any else missing the little white hose clamp thingy that is over by the radiator cap/PS I believe it holds a vac line....I am going to try and make them.....just seeing if anyone else has the need before I start this project
Its the Vac tube clip that attaches to the small coolant tube that bolts to the plenum, will post pics later
LGAFF is online now   Reply With Quote
Old 04-04-2011   #2
bdw18_123
Default Re: Little White hose Clip thingy
I believe this is what you are talking about, Lee (red arrow):
Only the 91-95 ZR-1's have this. The 90 ZR-1's don't (see pic below). Does anyone know what this extra vacuum line is for that they added?
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 04-04-2011   #3
Thats it!
Old 04-04-2011   #4
I'll take one. While you're at it, make the black clip that holds the fuel lines bolted to the evaporator case.
Old 04-04-2011   #5
ZR1@gmx.com
I would like one of each!
Fun 91 #303
ZR1@gmx.com is offline   Reply With Quote
Old 04-05-2011   #6
4DSZR1
4DSZR1's Avatar
Id take at least 3
Rick
4DSZR1 is offline   Reply With Quote
Old 04-05-2011   #7
Brillo1990
While you're at it Lee make some of the spark plug wire holders on the rear, I broke one of mine last week.
Brillo1990 is offline   Reply With Quote
Old 04-06-2011   #8
DaveK
I'll take a couple - mine is all loose and keeps popping out... errrr....
1991 #1516 Black/Black
davidmkelly.com
Old 04-06-2011   #9
zr1don
I believe that is a clip for the vacume line that goes to the charcoal canister for the fuel tank vapor recovery system on the later model LT5's. On the 90 that line comes out behind the A/C compressor and goes to the charcoal cannister under the left headlight.
Old 04-06-2011   #10
ScottZ95ZR1
ScottZ95ZR1's Avatar
Please put me down for a couple, Lee.
ScottZ95ZR1 is online now   Reply With Quote
