I'd like to sell it to someone who can try it out first, as the fit of these things is less than perfect. So you can be sure the fit is good enough that you are satisfied with it.
$75 Here's a shot of it on my car, and also you can see the fitment to the airbox: ![]() |
![]() Join Date: Feb 2009
Bob,
I'd be interested. PM me and we can work out the details. Rich
1990 Bright Red Coupe #608 380 Stroker, Ported Heads/Intake/Housings/TB Haibeck Secondary Delete Chip / Pete's Cams George Braml Intake / FIC Injectors Coated SW Headers / Corsa Bill Boudreau B/B ZF6 / Viper 4.10 gears Ron Davis Radiator Pioneer AVIC-Z140BH NAV Fikse FM5's 285 / 335 / C6 Brakes WAZOO Member Last edited by Scrrem; 02-27-2011 at 06:03 PM. |
Hopefully it'll fit up better than that water pump!
Man, don't plan a picnic on any days that Rich and I meet up! Always seems to be bad weather.
Good seeing you today Rich, and let me know how the duct fits up. |
#5 | |
Rich
Does it fit worse than in my picture? You have to sort of "center" it between the air horn and airbox to get it on both with reasonable engagement.
And no, it comes from Samco so long that it bows up and lifts the airbox assembly. You absolutely have to trim it the way they deliver it. Which I did. Let me know if you want your money back for it, it's no problem. |
#7 | |
Rich
![]() Join Date: May 2010
Hey Bob,
Just curious to know if it was difficult to get a straight edge when you trimmed it. I know what you mean about it being almost 1 inch to long and I finally had trouble with mine interferring with the the A/C compressor when the clutch engages. It burned some and also hit the clamp, but mostly due to the air intake I have and difficult to get good adjustment. I'm going to yank off the intake filter system and put on the SLP claw as it fit and mounts well, I just have to trim off about 1/2 inch it seems so there is not so much excess and to cut the damaged edge that hit the compressor. I thought of adjusting the clamp where I want to trim and using it as a guide with a blade to get a straight edge. You're the only one I am seeing mentioned trimming so looking for advice if you found what works to trim. Thanks! Craig
That's what I did, I used the clamp as a guide. The edge was pretty straight, at least appearance-wise. It can still end up being crooked in that the bottom is shorter or longer than the top of it. Though I think if it's totally even, it still can end up crooked when installed, as there is an angle between the air horn and the air box.
It's basically a big pain. So make sure it's really pissing you off enough that you just have to trim it... |
#10 | |
