Old 02-05-2011   #41
Locobob
Default Re: Some "Dynomite" Heads!
Thanks for the encouragement everyone
Quality of work is what I really strive for in doing this, takes forever but I think its worth the extra effort.
Robert
Old 02-14-2011   #42
Locobob
Almost done with the intake side of the heads. At this point I am mainly working the area around the valve boss and guide in an effort to provide a smooth channel for the air around these obstructions.
Robert
Old 02-24-2011   #43
Locobob
Switching gears to the exhaust side, the stock valve guide bosses are huge and don't blend well into the overall port - much like the primary bosses on early style injector housings. The casting compensates for this somewhat by extra port width in this general area.
Here we have: left side boss with just a little bit of blending around the perimeter, right side boss with some rough cut size reduction.
Some more rough cut reduction and blending
A little closer shot of the same
View from header side. Interestingly I have found that "as cast" one exhaust runner tends to be slightly larger than the other - near where they come together.
Robert
Old 02-24-2011   #44
Pete
Pete's Avatar
Rob,very nice
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-24-2011   #45
Locobob
Rob,very nice
Pete
It's getting there. Maybe if I take my sweet *** time you can talk Cliff into doing some cams
Robert
Old 02-24-2011   #46
Pete
Pete's Avatar
$750 adds another 20-25 hp
I have a set done on the shelf no waiting,i would need his stock intake cores.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-24-2011   #47
RICKYRJ1
RICKYRJ1's Avatar
Nice Job Rob, nice to see the work of a true craftsman who cares about the final results of his hard labor
Old 02-24-2011   #48
1990 quasar blue
Pete
Wow. Someone would have to be crazy to go through all the time and expense of head porting and leave at least 20 more horses on the table for 750.00. Sorry to get off topic Rob phenomenal work as always. A surgeon with a grinder.
1990 ZR1 #2574
Medium Quasar Blue Metallic
1 of 19
Old 02-24-2011   #49
Pete
Pete's Avatar
Pete......do you have a thread somewhere describing what you do to cams
Why only the stock intake cores?
Can I use my original lifters?
Robert........how are we going to attribute HP gain to porting if I use Pete's cams
Well i figure you want just Intakes.
If you want exhaust cams i would also need your stock ex.cam cores.
Specs:
Intake
.236 .425
Exhaust
.220 .425
What do you mean by what i do to them? of course i don't have the machinery to regrind cams i send them out.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-24-2011   #50
Pete
Pete's Avatar
The exhaust cams are worth about 5 hp.
With intakes alone you will see 15-20 add exhaust will 25.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
