Old 01-04-2011   #1
todesengel
Default Opened my shipment from Jerry today..
I have never taken one of these apart, and how he individually wrapped, and labeled every single bolt, screw, bracket, etc I could put it together with no problem lol.
Hats off Jerry, it is always nice to see such attention to detail!
todesengel is offline   Reply With Quote
Old 01-04-2011   #2
todesengel
Default Re: Opened my shipment from Jerry today..
What is it that you received in pieces? A crate engine?
close, in bags no less lol
Gasket, coolant outlet pipe (1 pair) 1
Gasket, cylinder case vent cover 1
Gasket, engine front cover 1
Gasket, oil pan 1
Gasket, oil pump access cover 1
Gasket, water pump 1
Seal, engine front cover 1
Seal, timing chain access bolt (set of 2) 1
Seal Set, oil pump o-ring (set of 4 seals) 0
Seal, PCV tube (set of 2) 1
Seal, timing chain tensioner (set of 2) 1
Seal, oil pan drain plug 1
PARTS
Bolt, Camshaft Sprocket [0060-1] 4
Pulley, Water Pump [0061-1] 1
Bolt, Water Pump Pulley [0061-1] 4
Bolt, Lower Alternator, M10 [0061-1] 1
Bracket, Lower Alternator [0061-1] 1
Alternator, used [0061-1] 1
Bracket, Top Alternator [0061-1] 1
Bolt, Top Alternator [0061-1] 1
Shield, Alternator Fan [0061-1] 1
Bracket, Rear Alternator [0061-1] 1
Compressor, A/C [0061-1] 1
Bolt, A/C Compressor [0061-1] 3
Bracket, Power Steering [0061-1] 1
Pump, Power Steering [0061-1] 1
Pulley, Power Steering [0061-1] 1
Reservoir, Power Steering [0061-1] 1
Hose, Low Pressure Return [0061-1] 1
Hose, High Pressure [0061-1] 1
Bolt, P/S Bracket to Cyl Head [0061-1] 3
Bolt, P/S Pump to Bracket [0061-1] 3
Tensioner, Serpentine Belt [0061-1] 1
Bolt, Belt Tensioner [0061-1] 1
Belt, Serpentine [0061-1] (purchase locally) 0
Sensor, Cam Position [0064-1] 1
Shield, Cam Position Sensor [0064-1] 1
Bolt, Cam Position Sensor [0064-1] 1
Starter [0065-2] 1
Bolt, Starter [0065-2] 2
Coil Pack Assy (not required) 0
Hose, Crankcase PCV, LH [0065-2] 1
Hose, Crankcase PCV, RH [0065-2] 1
Clamp, Crankcase PCV Hose [0065-2] 4
Chain, Secondary, LH 1
Facing, Sec Tmng Chain, LH, Fixed 1
Facing, Sec Tmng Chain, LH, Pivot 1
Facing, Sec Tmng Chain, LH, Top 1
Chain, Secondary, RH 1
Facing, Sec Tmng Chain, RH, Fixed 1
Facing, Sec Tmng Chain, RH, Pivot 1
Facing, Sec Tmng Chain, RH, Top 1
Chain, Primary 1
Facing Primary Timing Chain 1
Old 01-04-2011   #3
Pete
Pete's Avatar
Yeap,
Jerry,is the man.
He packs them good.
He ships them fast.
He's not from this world.
He must be Superman.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 01-05-2011   #4
bdw18_123
Yup, Jerry is pretty awesome. I ordered an almost full set of gaskets & seals for my LT5 from him a month or so ago and they were packaged the same way, individually bagged & labeled. Plus a little hand-written thank you note by him on the receipt as well. You can tell he really does care about his customers, its not just a bunch of talk like a lot of others.
If only all businesses were conducted the way Jerry runs his...
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
