Go Back   ZR-1 Net Registry Forums > Club Regional Areas > Mid-Atlantic Region
Old 12-10-2010   #11
Scrrem
Scrrem's Avatar
Default Re: WMD - Sunday, December 12th, in Westminster, MD
Originally Posted by QB93Z View Post
Hey Rich, what sealant did you use to seal the differential to the bat wing?
Thanks, Jim
Jim,
This stuff was a close as I could find to OEM sealer, worked pretty well.
http://www.permatex.com/brand_right_stuff.htm
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 12-10-2010   #12
Originally Posted by RICKYRJ1 View Post
I beleive he is going back to stock gearing. You know him, he changes stuff on his car as much as he changes his underwear.
I resemble that!!!!!!
Old 12-13-2010   #13
Aurora40
Aurora40's Avatar
It was a pretty crappy day yesterday, weatherwise, how did the WMD go? I was too afraid to drive up there in case the weather turned worse. They were calling for possible hail/snow.
Bob Saveland
Former owner of #2517
Old 12-13-2010   #14
QB93Z
QB93Z's Avatar
The weather was crappy. But, we accomplished a lot in a long day of wrench turning. I want to post an extreme thank you to Phil, Darrin, Yun, David, and Dennis for their invaluable help in accomplishing all of the jobs I wanted to get done.
We replaced all of the rear suspension bushings, replaced all U-joints, and ended up replacing the differential.
I will post some pics a little later.
What started out as a "simple" task to stop a very small leak from the differential, turned into a major replacement job. Upon disassembly, we discovered that the differential had been modified/replaced sometime in the past and that I had been running a 3.72:1 rear end ratio. In addition, the drive shaft connection to the differential had an old style, U-bolt to hold the U-joint so we had to replace the input shaft.
With Phil's expertise, David's spare differential and a couple of trips to the auto parts store, we were able to return everything to stock.
After a short test drive in the rain, I am very pleased with the results of all the work. The car runs and sounds better than it ever has.
Thanks again for all the help.
Old 12-13-2010   #15
QB93Z
QB93Z's Avatar
As promised here are some pics for Sunday's WMD:
Exhaust, C-Beam, and driveshaft removed, half shafts disconnected:
Differential removed and disassembly underway:
Batwing ready for new bushings:
Pumpkin installed to the Batwing:
Installing the rear spring:
Installing the rear spring, passenger side:
Old 12-13-2010   #16
Scrrem
Scrrem's Avatar
Great pictures Jim, wish I could have been there.
Rich
Ron Davis Radiator
Old 12-14-2010   #17
RICKYRJ1
RICKYRJ1's Avatar
Nice Job! Glad you were able to get her all done. Z brotherhood at its best!
Old 12-14-2010   #18
Look's like a nice productive day for all ! Don't you just love it when a nice group get's together ? Would have really like to been there.
Why is David biting his lower lip in the pic's ? Didn't anyone feed him ?
Old 12-14-2010   #19
QB93Z
QB93Z's Avatar
Funny that you should ask:
Old 12-14-2010   #20
QB93Z
QB93Z's Avatar
The collective talent and supplies of a group of ZR-1 owners is simply amazing. And I was lucky to have 5 of the best help me out.
