Old 06-10-2006   #1
tccrab
tccrab's Avatar
Default Dreaded No Start fixed (hopefully...)
After the second stranding event, I finally decided to fix the problem once and for all.
I was never able to successfully diagnose the No Start to my satisfaction.
I'd chased wiring, changed relays, checked connections, checked the clutch safety switch, actually learned what the VATS system does and how to arm and disarm it, but in the end I never really felt that I had isolated the problem, or corrected it.
You just can't trust a car that won't start. Especially if you can't figure out why it won't start, only to have it start just fine a couple of hours later for no aparrent reason.
What's the sense of starting it, only to dread ever turning it off for fear of the Dreaded No Start?
It would almost be OK if I always drove it from home back to home. But gosh forbid if I ever wanted to take it to a car show or go for a long cruize and spend the night somewhere.
If any of you should experience the same frustration here's what to do.
Cut the purple wire inside the big loom just aft of the ECM. Run a hot lead and ground from the battery using #10 wire. Splice into the cranking circuit (it a yellow wire under the dash) using a #10 wire. I found the easiest place to access it is at the CRANK fuse in the secondary fuse panel under the hush panel on the passenger side. I ran a #10 wire through the door vent grommet and carefully hid it up against the firewall, zip tying it to the windshield washer tubes. I used black wire to help in hiding it.
I used a Bosch 5 pole 30/40A relay, here's a link to a common diagram:
http://www.the12volt.com/relays/relays.asp
Connect the purple wire from the starter to the normally open pole #87. Battery 12v goes to pin #30, ground to pin#86, cranking circuit (yellow wire) to pin #85.
I hid the relay just under the EMC, so that it's not immediatly visible, yet still accessable.
What my mod does is to use the 12v that originally triggered the starter to trigger a relay which allows 12v DIRECTLY from the battery to the starter solenoid. The current that triggers the starter solenoid does not wander all over BFE, under the dash, through the clutch switch, VATS, SIR, ECM, CCM, etc., etc.
When you turn the key, the starter WILL engage.
The VATS system can still shut off the fuel and the ignition so even though the car could crank, it won't start if the VATS is triggered.
The cluch safety switch is bypassed, so it is possible to start the car with the cluch out, but that's hardly a major drawback. Anybody that has starting issues usually wires that POS switch out right away.
Now if she won't crank, I've only got three possible things to diagnose. The relay I just installed, the starter/solenoid, or the ignition switch.
Cost of the project, approximately $25, and took about 3 hours to do. Hardest part was getting to the yellow wire under the dash and figuring how to get it through the firewall.
The peace of mind knowing that it will start every time I turn the key?
Priceless!
TomC
'90ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 06-11-2006   #2
Z Factor
Z Factor's Avatar
Default Re: Dreaded No Start fixed (hopefully...)
Very interesting.
Old 06-11-2006   #3
Wow, I admire your understanding of this stuff Tom!
I'm as dense as a rock & just as dumb when it comes to this stuff. Thanks for the link to that site... if I study it enough I hope to learn something.
The electrical system in this car intimidates me as much as anything going wrong inside the motor....well maybe except for a failed heater core
Thanks for sharing that site address!
Old 06-14-2006   #4
ZR1Trev
I'm no expert, but I think the basic problem is too many places for a voltage drop before the 12V reaches the starter solenoid. The soleniod won't energize unless everthing is in perfect working condition (battery, connections, clutch switch, relay etc). This problem usually shows up when the soleniod is hot, after about a 10 or 15 minute engine shut down period.
You solved the problem by eliminating the voltage drop. I sovled the same problem by replacing the starter and solenoid (after I proved that everything else was okay). I still have the voltage drop, but now I have a new soleniod that can live with the voltage drop.
Trev
ZR1Trev is offline   Reply With Quote
Old 06-15-2006   #5
tccrab
tccrab's Avatar
Trev
Trev:
Bingo!
That was exactly my conclusion.
Try as I might, I could NOT find a single reason why it wouldn't crank the starter.
I checked everything I could check with my limited skills and diagnostic tools and I could not find a single failed component.
And to add insult to injury, after an undetermined period of time, the goshdarned thing would just fire right up with a turn of the key.
So, it was my conclusion that it wasn't a single problem, but instead a combination of little problems that caused my Dreaded No Start
(I capitalize and bold it because of how frustrating getting stranded can be, only to have it start for no good reason a little while later and make you look like an idiot in the mean time)
In my daytime life, I run and repair very sophisticated laboratory equipment.
I won't bore you with the details, but I've learned the hard way that an intermittent problem is the absolute WORST kind of problem there is.
In the world of electronics, if you let out the magic smoke, the failed electronic component is fairly easy to diagnose and repair.
If the !@##$%% piece of !@#%%^ won't fail completely, it's nearly impossible to diagnose and repair unless you're lucky enough to see the fault first hand.
I've seen it twice, got stuck twice, and had to call for a lift home twice.
I WON'T SEE IT AGAIN.
The next time it fails, there better be Magic Smoke, or I'm gonna be pizzed!
TomC
'90ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 06-15-2006   #6
x-raydave
I've experienced this same problem and perhaps you've come up with a cure.
It actually happened at a corvette show last year and a couple of enthusiasts wanted to hear the LT5 start up and rev. Guess What? Damn thing wouldn't start. That's embarrassment. I have found out that a jump seems to take care of the problem. That in itself is embarrassing. What I now do is have a portable charge unit with me at all times and if this happens I open the hood up, hook up the portable unit and it seems to start. Perhaps someone here with knowledge can steer me to the correct part replacement if all it takes to start is more voltage. The battery is fine and the car will start 10-40 times no problem, but then at the most embarrassing time - NO START! I agree intermittant problems are a bit$h. I would rather have something just poop out and let me replace it. Thanks for letting me rant. I am going to a car show on Saturday and if this happens again (I'm almost sure it will) car has been starting fine for weeks, I will once again suck it up and be embarrassed.
x-raydave is offline   Reply With Quote
Old 06-16-2006   #7
tccrab
tccrab's Avatar
Sounds to me like a battery or battery cable problem.
When my No Start happened, jumping it did not make it start.
I'd bet dollars to donuts if you'd replace the battery and the cables the problem would go away.
Have you cleaned the battery terminals? A stiff wire brush is all you need, rough it up a little and knock off any corrosion.
Good luck!
TomC
'90ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 06-16-2006   #8
Locobob
Been spending some quality time with my electrical service manual trying to get a handle on this. Assuming the 90 and 91 are wired the same how come you didn't splice into the cranking circuit (yellow wire) just before it goes into the starter enable relay? Looks like it's right under the steering column and would be a much more direct path than the fuse panel.
Robert
Old 06-17-2006   #9
95ZR1#418
95ZR1#418's Avatar
Whatever, TC-
You did a great job. Personally, I would have sold the car for scrap within hour 1...
Later-Bob :D
[IMG]http://www.axoplasmic.com/800x600/toponzr1.jpg[/IMG][IMG]http://www.axoplasmic.com/800x600/topoffzr1.jpg[/IMG][URL="http://axoplasmic.com/AXOPLASMIC/ZR1.html"]My '95 ZR-1 Home Page[/URL]
95ZR1#418 is offline   Reply With Quote
Old 06-17-2006   #10
tccrab
tccrab's Avatar
Actually, the manual make's it look all too easy.
I poked around under the drivers side and came to the conclusion that there wasn't all that much room under there to get at the wire and to splice into it.
The clutch safety switch (another place to get at the Crank voltage)is WAY up under there and I didn't want to take apart the entire dash and/or the steering column to get at the stupid wire.
I'd already had the passenger hush panel off and had seen the CRANK fuse and knew it was much easier to get at than any wire on the drivers side.
The path of least resistance is always a favored bet.
TomC
'90 ZR1 #792
TomC
'90ZR1 #792
Honorary Pirate
[/B]
