09-11-2023 | #1 |
WTB - ZR-1 Radio Antenna Bezel / Grommet
Looking for a replacement ZR-1 antenna bezel. Does anyone have an extra that they would part with?
Had to replace my antenna and learned the hard way that apparently this is a ZR-1 specific part. -Jackson
'90 #413 Red/Red Sold '90 #1583 Red/Red |
09-12-2023 | #2 |
Re: WTB - ZR-1 Radio Antenna Bezel / Grommet
I have one but what happened to yours if I may ask?
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Parts car Hit me up if you need anything. |
09-13-2023 | #3 |
I had a broken antenna mast...instructions on the new one said to remove the grommet in order to replace the mast with the antenna unit remaining in the car. I had purchased a replacement grommet online since I figured it might break apart when removing, and it did. Unfortunately, when I was finished replacing the antenna mast, I discovered that all of the replacement grommets online are for standard C4's.
I will send you a PM about the one you have.
09-13-2023 | #4 |
How do you determine the difference standard C-4 verses ZR1? Part #?
Reason I ask is I might have one.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
09-13-2023 | #5 | |
If it's in its original GM parts bag, the part number is 14104620, I believe.
01-03-2024 | #6 |
I have two of these one in the GM box with #14104620 and a second without the box. The question is a fair price for this NLA part?
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) Last edited by jrd1990zr1; 01-04-2024 at 10:04 AM. |
4 Days Ago | #7 |
I?m interested in the bezel if it?s still available.
09-13-2023 | #8 |
They are slightly different due to the ZR-1s wide ***.
09-14-2023 | #9 |
Well I dug out the one I have in my stash and mind you it came from a ZR-1 But it looks like the normal car version so I assume someone replaced it with the base car version. I guess I didn't notice at the time.
sorry It's not the right one. I have another one but its still on the car and I haven't parted out yet. Last edited by phrogs; 09-15-2023 at 12:08 AM. |
09-14-2023 | #10 |
Antenna grommet for ZR-1 has less slant angle on top because antenna location on rear fender is relatively flat on ZR-1s. They are different.
