02-01-2010 | #1 |
'91 missing and would like a second opinnion
I was hoping I could have figured this one out, but after a bunch of diagnostics I'm not really sure where to look next. So I would appreciate your guys second opinion.
At this point I have already measured, coils, wires and injectors and they are all perfect and also less than 1 year old. Also installed new plugs and they all look fine after my test runs. Also I do not get a check engine light. Car starts fine and runs perfect on idle. As soon as it warms up even a little bit the idle becomes rough and I start to hear occasional knock. when I take off it runs like a 70's vette at start and sometimes starts running smooth when I hit about 2000rpm. When I get it running normally under a steady throttle it runs fine, but starts stuttering when I step on it. So I'm wondering if O2 sensors could cause this and not give a check engine light or could it be the fuel pump?
If you don't put the miles on it, someone else will... |
02-01-2010 | #2 | |
Re: '91 missing and would like a second opinnion
Your symtom is similar to what I had. |
02-01-2010 | #3 | |
;-) Took me 3 years and more $ than I'd like to admit, but in the end, about $5 worth of pins and a hour or so took care of my misfire. http://www.zr1.net/forum/showthread.php?t=10828 Bottom line is, did you or your mechanic use the Haibec method of checking the Ohms of the old resistors? And when you did so, did you stick the probe of the volt meter directly into the ECM plug? I did and paid the price. You can't believe how hard it was to find, but you can believe the difference it made. TomC "Crabs
TomC '90ZR1 #792 Honorary Pirate [B]If it ain't FUN, you're doing something terribly WRONG. [/B] Last edited by tccrab; 02-01-2010 at 01:46 PM. |
02-01-2010 | #4 |
It's has only about year old Accel injectors, MSD coils, MSD wires and I had never pulled the ECM connector until this issue came up. So I don't think there is anything wrong with the pins in the connector...
02-01-2010 | #5 |
1990 Grey/Black Too many for the sig. |
02-01-2010 | #6 |
Mikko,
if you need help, let me know. KT
02-01-2010 | #7 |
Thanks Ken!
I will probably try to check the O2 sensors tonight, but after that I'm pretty much out ideas...
02-02-2010 | #8 |
02-03-2010 | #9 |
Hey, I wonder if now I/we can beat you at Spring Mountain?
PS Fuel Filter? Last edited by tf95ZR1; 02-03-2010 at 02:23 AM. Reason: Wanted 2 |
02-03-2010 | #10 |
If I can get this thing running again I wont even care if you beat me
Fuel filter was changed 2 years ago. After reading "Crabs" story I'm very hesitant to just start throwing new parts at it.
