Thread Tools | Display Modes |
![]() Join Date: Dec 2005
10 second Vette build for Drag racing, but still street legal and street drive-able. Clean Las Vegas based 1993 Corvette with supercharged 383cid LT4 motor with only 70k miles on the chassis.
Black leather interior in perfect condition with Corbeau seats, full roll cage, 5-point seat belts and fire extinguisher. All stock accessories are still on car including air conditioning (not charged). This Vette has always been garaged and cared for inside and out as you can see in the pictures. It is currently street drive able, but would need to have the head gaskets to be replaced for WOT track racing. Also included stock LT1 engine complete with 50,000 miles, Procharger P600 SUPER CHARGER, BBK throttle body, 24 LBS fuel injectors. I have all documents available for all parts. Additional Weld racing drag racing rear wheels with ET Street tires on them Please let me know if you have any additional questions or would like additional pictures. List of mods made: CAR……………………………………… …………….1993 CORVETTE LT4 RACE WEIGHT…………………………………… …3333LBS ENGINE…………………………………… ………….LT4 383 CID. BLOCK……………………………………… …………….LT1 4 BOLT MAIN COMPRESION RATIO……………………………….9:2 HEADS……………………………………… ………………PORTED LT4 2:02 / 1:625 VALVES INTAKE MANIFOLD…………………………………..L T4, PORTED AND PORT MATCHED CAM……………………………………… ………………CRAIN CAM HYDALIC ROLLER 222 / 230 DURATION AT .050, .559 / .580 LIFT ROCKER ARMS……………………………………… CRAIN GOLD RACE ROCKERS 1.60 RATIO PISTONS…………………………………… …………..J E FORGED PISTONS, 4.040 BORE RINGS……………………………………… ……………….CHILDS & ALBERT Z-GAP CRANKSHAFT………………………………… ………EAGLE 4340 STEEL. 3.75 STROKE BLOCK……………………………………… ………………..ARP MAIN & HEAD STUDS RODS……………………………………… ……………..CARRILLO 6” RODS ENGINE BALANCE……………………………………. .INTERNALLY BAL. BY KELL’S MACHINE SHOP BALANCER…………………………………… ……………ATI CUSTOM BUILT WITH ADDITIONAL 8 GROOVE FOR SUPER CHARGER SUPERSCHARGER……………………………… …ATI PROCHARGER D1SC @ 21 PSI BOOST PULLY……………………………………… …………….REICHARD RACING PULLY, CUSTOM BUILT 8 GROOVE, FOR D1SC PROCHARGER INTERCOOLER………………………………… ………SPEARCO CUSTOM BUILT AIR TO AIR BLOW OFF VALVE…………………………………..ATI 1.5” RACE VALVE THROTTEL BODY…………………………………….EDE LBROCK / BBK 58 MM BILLET INJECTORS………………………………… ………….BOSH 72 LBS / HR. FUEL PUMP……………………………………… …AEROMOTIVE A1000 SUMP MOUNTED / AEROMOTIVE FUEL PUMP COTROLLER & FUEL PSI CONTROLLER OIL PAN……………………………………… ……….CANTON 8 QT. WITH TRAP DOORS OIL PUMP……………………………………… ……MILDON HIGH VOLUME PUMP RADIATOR…………………………………… ……….UPGRADED ALUMINUM ENGINE MANAGEMENT ………………………..FAST SYSTEM ELECTRONIC, LAP TOP PROGRAMABLE INGNITION………………………………… ………MSD 6AL. MSD BLASTER HVC. MSD WIRE SET DISTRIBUTOR………………………………… ……..MSD PRO-BILLET. CUSTOM MOUNTED AT REAR OF INTAKE MANIFOLD EXHAUST SYSTEM………………………………..1.75 HOOKER LONG TUBE CERAMIC COATED HEADERS, 3” BILLY BOAT EXHAUST SYSTEM TRANSMISSION……………………………… …700R4, SR7 PERFORMANCE, SHIFT KIT TORQ CONVERTER……………………………….3000 RPM STALL DRIVESHAFT………………………………… …..ALUMINUM, BALANCED, PERFORMANCE U-JOINTS. DRIVE SHAFT & ½ SHAFT SAFTY LOOPS DIFFERENTIAL……………………………… …..DANA 44. 3.33 GEAR RATIO BRAKES…………………………………… ………..DRILLED / SLOTED ROTORS, CERMIC PADS GAGES……………………………………… …………..PILLER MOUNTED FUEL & BOOST NOS……………………………………… ……………NOS SYSTEM, WET 150 HP, LIGHTED PURGE VALVE, BOTTEL HEATER, BLOW OFF VENT TUBE CAGE……………………………………… …………5 POINT ROLL CAGE WITH SWING OUT DRIVER SIDE BAR BELTS……………………………………… …………….G FORCE 5 POINT WITH QUICK RELEASE WHEELS…………………………………… …………WELD WHEEL REAR RIMS & MT STREET SLICK DYNO REAR WHEEL 12-17-2011…………….. 782 HP / 746 TORQ Asking $14,500 I'm posting this for a friend of mine, but I can answer any questions you may have. Feel free to pm me if you would like to find more details about the car by phone.
If you don't put the miles on it, someone else will... |
