01-14-2020 | #1 |
Cleaning original wheels
I have the original set of wheels for my 93 ZR-1. I would like to clean them but I tried high pressure wash on the inside of the wheels but met with limited success. What has everyone done to clean up their wheels?
Roy L. Carman If I feel the need for speed, I just think about flying the B-777. 1989 Dk Blue Coupe lost in divorce 1991 Black Coupe SOLD 1992 Black ZR-1 #423 SOLD! 1993 Ruby Red 40th Anniversary ZR-1 #334 1995 Black ZR-1 taken by ex-wife 2002 Pewter Coupe no idea where it is 2003 50th Anniversary Corvette #No idea what number SOLD! ZR-1 Net Registry #516 Grand Sport Lifetime Member NCM Lifetime #1468 ZR-1 Net Registry Board Secretary |
01-14-2020 | #2 |
Re: Cleaning original wheels
Hey Roy, This recipe I'm passing on to you is for the inside of the wheel ONLY!
I use Mothers Wheel & Tire cleaner its a strong detergent that works very well, after a minute of Mothers W/T soaking I use the 3M Ultra Fine (Gray) in color scouring pad, elbow grease is required. Do this twice a year and you will maintain that factory finish. |
01-14-2020 | #3 |
Cool. Thank you. I have three sets of wheels to do so that will keep me busy.
Roy
01-15-2020 | #4 |
Roy, Try to purchase Mothers Wheel & Tire cleaner by the gallon rather than the 28oz spray bottle that most auto supply stores have, if I remember correctly I paid $25.00 per gallon @ Carlisle (2) years ago.
01-15-2020 | #5 | |
Roy
01-15-2020 | #6 |
Dawn dish soap for the painted and polished wheels.
01-16-2020 | #7 |
Factory polished is still clear coated so treat them like painted. Dawn or Ivory dishwashing soap. I have also used Simple Green on the inside of the wheels cut with water starting at 20% S.G. and rest water. You can always increase the strength. Joel
Joel Tampa/Rockledge, FL Present Collection 1969 350/300 AC Convertible 1972 454 Coupe 2nd Owner 1988 KOH EX5006 - ZR-1 Prototype 1990 ZR-1 #277 NCRS Dave McLellan Award 2019 1994 Copper Convertible NCRS Dave Hill Award 2012 2001 Z06 122k miles |
01-16-2020 | #8 |
Simple Green full strength! Won’t hurt anything and cleans pretty good too.
You can even soak your dentures in the stuff! (Rinse ‘em off before you slap ‘em back in your mouth though..) Buy it by the gallon at Home Depot or Walmart. I wouldn’t use it for car wash though, removes the wax... |
01-18-2020 | #9 |
The 92 wheel is painted and the 93 wheel is brushed with a clear coat. Once you get the wheel clean try sealing the surface with a ceramic coating,that would keep the brake dust from sticking to the surface.
01-18-2020 | #10 |
Thanks for the suggestions. I fo have a problem with my 92 wheels. It looks like some rust or something is under the clear coat. I was told that to fix that you would have to remove the clear coat and brush out the rust. Any ideas on that?
Roy
