08-07-2005 | #1 |
Scan Tool
Any recommendations on which scan tool is the best? Been thinking about buying one.
Don 1990 Dark Red Metallic #1587 |
08-07-2005 | #2 |
I'm in for an answer
08-07-2005 | #3 | |
If you want the easiest go Datamaster but it has no AFR readings, if you are willing to put in some time and effort into the mix then I would use Craig Moats's hardware, Tuner Pro to build a datalog of spark etc and FJO to get AFR data in a format that can be used to modify the prom which can also be done with TunerPro(Tunercat also works but does not give you a datalog capability). This would give you the best package. With these packages you can define your own outputs ie dataloged information, review AFR and burn your own chips. Both TunerPro and Tunercat use data definition files, you can buy them for Tunercat. Todd P has done one for the 90 and 91 for TunerPro not sure if anyone has tried to do one for 92+. Tyler
55 Polo White (Project) 61 Jewel Blue (Sold to buy above) 66 Nassau Blue 68 Torch Red 88 ZR1 Blue 90 ZR1 White |
08-07-2005 | #4 |
I agree with Tyler's comments above. Personally I use Datamaster for all my normal datalogging. Nice package.
One day I will convert to TunerPro, since it is a lot more flexible (you design the definition file). However, I still can't get it to connect to my car. 90+ vettes need a "silence" command to stop the chatter on the ALDL line before software can connect. Mark Mansur (TP creator) will integrate this feature into a future version, I hope. P.S., if anybody has gotten it to connect, I'd like to hear from you. As Tyler says, if you want to monitor the standard GM ECM data, Datamaster is a fine tool. Some of the wideband O2 controllers (FJO) will let you connect to multiple analog, 0-5v inputs. I run mine connected to the MAP signal and tach signal. With such, I can get nice 3D recording of AFR vs. MAP vs. RPM. A little Excel spreadsheet magic, and I can turn it into a Volumetric Efficiency table. I use the wideband logging 90% of the time, and only pull out datamaster if I try something really different with the calibration, just to make sure all the inputs look normal. Hope this helps. Todd |
